Rusty Bus Floor!
Hello!
I am currently in the flooring process of my bus. Everything has been gutted out at this point, we even started sanding the floor and spraying it.
Here is the process that we took sometime ago.
Gutted the bus, sanded the floor/rust, Painted corroseal on the newly sanded parts, then whatever didn't turn black we sanded again, did another layer of corroseal and then spray painted what was converted to prevent more rust.
Here's where we messed up...Leaving the windows down and the roof emergency door open, and it rained...oops!
So here's my question. To save time because I am heavily approaching my deadline...should I just sandblast the floor? I just watched a video of someone sandblasted with aluminum oxide and a sandblaster that he got from harbor freight. It worked pretty well...I'm just not sure that it's going to thoroughly do the job. I just want the rust GONE!
Most of the large wholes by the wheel well was so rusted that it ate through it. Those large wholes have already been wielded. Now there are only the small wholes where the bolts were for the seats. I've seen where someone put caulk and pennies on top. I don't want to have to weld those small areas. I don't think its worth it at that point. Any suggestions? I'm really looking for a step by step tutorial!
Also I am learning all of this mainly on my own. I learn fast and can do thorough research once pointed in the right direction. So please be patient with me! Thanks!
