Old 08-04-2018, 06:02 PM   #1
Securing emergency vents?
I've got 2 emergency vents I'd like to secure but I'm at a loss for a good way that doesn't look horrible. Is there an existing solution for making my vents more burglar proof?
Heavy is offline   Reply With Quote
Old 08-04-2018, 07:11 PM   #2
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
if all you are wanting is to make them non accessible open them and glue them shut with liqiud nails Fuse it Siliprene or some other super high strength adhesive however if they are fiberglass that will not keep some one from sticking their foot through it and gaining entry then you need to remove cover and replace with sheet metal. Gene
Gdog 5651 is offline   Reply With Quote
Old 04-30-2019, 01:50 PM   #3
CMORGANSKOOL's Avatar
Coachwork: IC
Chassis: FE Bus
Engine: DT-466 7.6L Turbo Diesel
While my bus was parked in the city (before I found a secure storage lot) I cut squares of chicken wire and screwed them to the ceiling over the hatch holes. Not perfect or pretty but it would delay a would be intruder long enough to either quit or hopefully get notice trying to kick through the chicken wire barrier.
CMORGANSKOOL is offline   Reply With Quote
Old 04-30-2019, 01:58 PM   #4
ermracing's Avatar
Engine: DT466E (195hp, 520tq)
Rated Cap: 29,000
We bought some little hooks and eyes with the springs on the hook side to keep them latched. We haven't installed them yet, however. Obviously nothing is total intruder-proof but these look like they will keep the hatches from being popped up easily.
Dave
Old 04-30-2019, 04:56 PM   #5
Fixed the security issue AND the leaks!
Roll Your Own Build Thread
