Originally Posted by ol trunt
You should be OK with Sikaflex 1A as long as it is for sealing only. If it is to also secure the glass then Sikaflex 220+ would be the right stuff. Both products are easy (and messy) to use, sort of clean up with mineral spirits (nothing else) and are paintable with water or oil base paint.
Hello Jack -
We're using Sikaflex 220+ for the windows where the glass meets aluminum (and considering Dynatron 550 for seals), but what kind of sikaflex would we use for other stuff, like bus seams, and between roof metal and a polycarbonate skylight?
And do we need to clamp after any of these applications?
Thanks so much!
