Originally Posted by stlthe
Ahh, so the gutters are held on, if somewhat poorly, just by the screws. I am relieved to here that and it explains the leakage. It also allays my fear that removing those screws would cause the side of bus to fall off.
Did you have any rust problems behind the gutter?
Thanks Oscar
Evan
Hi Evan
No I had no rust issues but I think I got it early, but mine was definitely leaking behind there which like you said puts the water in a direct path to the windows. Also make sure you do the gutter over the rear door(same issue).
In my opinion the bus manufactures and school districts have a predetermined life expectancy of these things and they are built to that standard. If you know a school district cycles their buses out at 10 years do you build a 30 year body or do you focus on safety and reliability. I think safety standards not longevity are the priorities.
I use Dap brand polyurethane from Home Depot for most sealant jobs, inexpensive, good adhesion, dries quick, paintable. Don't recommend silicone anywhere outside of bathroom tile.
Good luck with your work
Cheers
Oscar
