Old 10-04-2020, 05:59 PM   #21
so i did the roof raise on my thomas bus. zero issues lifting from the window rails. it went up easy and lined up no problem.
Bigbadbus is offline   Reply With Quote
Old 10-05-2020, 08:47 AM   #22
shaymcquaid's Avatar
Chassis: 40' MVP-ER
The angle on Thomas is a non issue.
shaymcquaid is offline   Reply With Quote
Old 10-07-2020, 04:31 PM   #23
Originally Posted by FAC View Post
Yes I’ve done it, it must be somewhat more challenging than a completely flat sided bus but I’ve never done one of those so I can’t say how much worse it would be? I tend to think if you have the skills to form the transitions properly and make them look good the small angle of the walls would be easy For you to compensate for.
Hi there can I ask where in Central CA I also live here and can not find anyone to help raise my roof. Would you consult or direct me to some help??
justcall is offline   Reply With Quote
Old 10-07-2020, 04:48 PM   #24
Where are you in Central CA I Have looked for help and can not locate a soul. Wait I have found several but they ghost me soon after. Any direction would be GREATLY APPRECIATED!!
Old 10-09-2020, 04:45 PM   #25
FAC
Engine: Cummins 24valve 5.9
I am in mariposa, where are you? I just watched as many videos as I could find and read the threads with roof raises and chose how I would do it. It was pretty straight forward.
FAC is offline   Reply With Quote
Old 10-09-2020, 07:31 PM   #26
Chassis: Ford E450
Engine: V10 Gas
That is a good-looking roof raise.
Old 11-15-2020, 06:47 PM   #27
So i pulled it off. It went smoooth as glass
ABA9BED5-4C04-4F63-9A92-741076925FAB.jpg   BFC25736-41CE-4DB2-8F3C-5A82AA003B94.jpg   7AD4A759-FDF3-4451-A05D-53BB88577223.jpg   D9F6C9B9-4A08-4CA8-8E15-12AE189D004F.jpg   703484D5-B792-47C7-BE63-6FC49C0A1019.jpg
3A4F328B-1392-4338-9584-0AFA342A839B.jpg   9A0FBAF9-C7F8-417A-8548-FE42A142D634.jpg
Old 11-15-2020, 07:07 PM   #28
Awesome.
Those are awesome pictures. I wish I was in a better position to raise mine. Yours looks so good keep up the good work
Old 01-10-2021, 07:49 PM   #29
Chassis: Saf-T-Liner
Engine: Cummings 8.3
Rated Cap: 44
Did you use any adhesive or sealant behind the sheet metal?
https://photos.app.goo.gl/MpJe7r7HokEXias56
Bouysou is offline   Reply With Quote
Old 05-25-2021, 10:03 PM   #30
Engine: 5.9 Cummins ISB-205/ Allison 2000
Good day,
Very nice job on your roof raise and bus.
I was wondering if you had a material list available?
I have a 2002 thomas (looks exactly the same as yours) and will be doing a 12" or 16" roof raise next month. I'm just not sure what to use inside the hat channel things.
If you could get back to me that would be greatly appreciated.
Thanks,
Kevin K.
Kevin1 is offline   Reply With Quote
Old 07-23-2021, 03:19 PM   #31
Year: 2006
Engine: Mercedes
Thumbs up Am I CRAZY or over thinking things
Thanks to those that gave great insight on how you did your roof raising! I have yet to pick-up our 2006 Freightliner/Thompson, within the next 4 weeks at latest. It all looks intimidating in my brain, yet says easy as .. at the same time. I am seeing some great work and craftmanship that given me hope that I have this too. Keep help out with good insight, as you are!
SawsSandBox is offline   Reply With Quote
