08-30-2020, 06:05 PM
Thomas roof raise
I have a 2006 Thomas built bus and im looking to do a roof raise. ive heard its difficult with thomas busses due to slanted hat channels. im looking for advice on how to over come this issue. anyone out there tackled a thomas roof raise?
09-02-2020, 04:38 PM
Engine: Cummins 24valve 5.9
Yes I’ve done it, it must be somewhat more challenging than a completely flat sided bus but I’ve never done one of those so I can’t say how much worse it would be? I tend to think if you have the skills to form the transitions properly and make them look good the small angle of the walls would be easy For you to compensate for.
09-02-2020, 04:44 PM
Best to start the raise below the windows, instead of in the middle of the windows. This will require removing more of the side material that normally would not be removed during a raise on another brand bus.
09-09-2020, 12:18 PM
Chassis: Oshkosh
Engine: 5.9L 6BT / MT643
Rated Cap: 26
I raised my thomas roof, first and only raise, it turned out great. The angles are a slight consideration but easily overcome.
09-10-2020, 07:08 AM
did you raise below the windows? or above. can i see some pics?
09-10-2020, 10:00 AM
Engine: CAT 3126
09-10-2020, 10:57 AM
Chassis: Oshkosh
Rated Cap: 26
I would never raise below the windows, unless I wanted to keep the original bus windows, which I never would. (I also wish it were easier to upload photos on this forum like it is on most social media platforms... What do people use here to host photos- photobucket?)
09-10-2020, 11:21 AM
Chassis: Oshkosh
Rated Cap: 26
Chassis: Ford e450
Engine: 7.3 Powerstroke
How are they overcome, and, why not raise under the angles/windows?
09-10-2020, 11:34 AM
Chassis: Oshkosh
Rated Cap: 26
Overcome? I clamped one end of the hat channel together then flexxed the other end in using more clamps, until the area was bridged across then I welded it together. Was not difficult at all.
Personally i would not raise under the windows unless i planned to keep the windows. Doing so i was able to install 36" tall windows without having to cut into the side rails AND i like the look better with what I achieved doing the raise on the upper section.
09-10-2020, 02:04 PM
Engine: CAT 3126
Nice look you have there.
09-10-2020, 04:17 PM
I calculated this on another thread, but it appears that if you do a 1' raise on a Thomas in the way you describe, the angle of the wall would be changed less than one degree (from 6° to 5.15°, or 84° to 84.85° rather). Seems like there would be more than enough flex in the wall base and the ceiling to accommodate that with no problem.
09-11-2020, 01:18 AM
Chassis: Oshkosh
Rated Cap: 26
The hat channels are easily flexed into where they need go.
If you were to cut at the same spot on each hat channel it would be easier to get all your hat channels more consistent, where as i made it more difficult by staggering the cuts high- low- high - low, w/ the intention of making the raise more structurally sound( by eliminating a shear-line/ in case of a wreck ).
Even if your a hat channel gets a little "wiggly" on you, the sheets still can turn out great. My channels weren't all perfect but the sheets turned out. i bridged one w/ a bit of sheet metal to fill on a gap i had going .
I'd also suggest using 18 gauge (galvanealed) sheets. 20 gauge will be harder not to crinkle your walls like some jiffy pop stove top popper.
Here's a couple more photo of my raise
09-11-2020, 01:34 AM
As long as you are taking out all of the windows, the slate is clean. Most all raises are cut at the windows, which assumes the windows are to be deleted anyway.
09-11-2020, 09:56 AM
Coachwork: 44' Newell Coach
Engine: 8v92T Detroit
Rated Cap: 2 adults and two pigeons
who's the source for new hat channels? Someone mentioned it and I lost my notes.
Thanks!
By the way, Your paint looks really nice Nova.
--Simon
09-11-2020, 11:56 AM
Thanks!
I have hat channel kits for an International. No one told me the measurements for a BB or a Thomas to see if they are similar.
Shipping to you might be a deal breaker.
https://www.skoolie.net/forums/f14/h...ale-29000.html
09-11-2020, 12:38 PM
Chassis: Oshkosh
Rated Cap: 26
I bought my hat channel extenders from Colorado Custom Coach.
Thanks! I just painted, still finishing trim..
Thanks!
09-11-2020, 03:48 PM
The place where you purchase your sheetmetal most likely have a fabrication shop as well and can make them for you.
09-12-2020, 05:49 PM
Rated Cap: 81
I did my roof raise at the windows also. I put the hat channel on basically the same way with clamps but I bolted instead of welding. The only things I had a hard time with was the 2 rear main supports on the corners. And attaching the Rv doors. Because of the angle I bolted in a piece of rectangle iron to the door jamb so I’d have something straight to screw the doors on to.
09-16-2020, 10:08 PM
Year: 2005
Engine: CAT C7 7.2liter
Rated Cap: 30,000
roof raise
I did my first roof raise on my 2005 Thomas. The most challenging part was the rear transition because we kept the rear a/c. I think it turned out great. ditched the original windows.
