Wall insulation - lots of prep questions
Hey folk! We've got the bus mostly gutted. It looks like I'll be able to get 1.5" foam boards in the walls and still not cover the chair rail (or 2" and only cover a bit of it).
When y'all gutted your walls, did you trim down the protruding screws that anchor the outside rub rails? Or just push foam directly onto them?
Any particular glue to use for polyiso foam? How do I minimize squeaks when driving?
The stuff I'm using has an aluminum face. Should I put that "face in" so it's rubbing on wood instead of steel?
I'm not adding any wiring inside the walls (no need, it's a very simple electric layout), but did you put anything over any 12v wiring (running lights, stop sign, etc.) before putting in the foam? How about at the back, where the tail lights are... Did you insulate directly over the light housings? Cut access holes?
Thanks a million!
Fat Boy
