10-10-2016, 05:04 PM
#21
Year: 2005
Engine: Detroit MBE906
Originally Posted by Goatherder
NO! You've got 8hr pot life after you mix in the catalyst. And I think that varies with temperature.
Thanks that's good to know.... I will need 2-3 gallons of paint (might get by with 2 since I'm just doing the bottom half in the blue, based on 400 sf per gallon coverage estimate from Home Depot website) and was just gonna mix up the whole batch at one shot to avoid color differences.... I guess I could mix all the paint together to even out the color, then just add 3 oz acetone and 2 oz hardener per quart as needed into the roller tray.
I hadn't considered doing the wheels to match.... if there's any paint left maybe I'll do that as well.
I'll also be painting the stop sign over (leaving it on because I don't want extra holes to patch.) I wonder if I could find blue light covers to replace the reds on the sign.... just to be clear they aren't going to be used, just to avoid the clash of red on blue.
10-10-2016, 05:50 PM
#22
on my new bus im going to try getting away with just making all the lenses orange or clear and see if i get bothered.. im gonna take the stop sign off and use rubber Plugs most likely to plug the holes. little silicon and theyll look like an option that was never installed
-Christopjer
10-10-2016, 05:53 PM
#23
Chassis: 3500 vandura
Engine: 6.5L GMC
Rated Cap: 16
I planned on mixing my two gallons of white and whatever amounts of blue and green to get aqua all in a 5 gallon bucket. Then I will pour out gallon, half gallon, whatever it is a need for the day and add the acetone and hardener accordingly to each batch. That way my paint color stays consistent. The hardener is 1 can per gallon and has a shelf life of 8 hours. So only mix what you might need at the time and you won't waste your paint or have the catalyst go bad. The acetone I will mix depending on how thick the paint seems and how it rolls. Thin enough to smooth out but not so thin it runs. Several thin coats are better than a thick one and you have less chance of the orange peel effect with thinner paint. I used to paint wooden boats and that was my approach ( minus the hardener). The bus is a first for me. Rustoleum is also a first.
10-10-2016, 06:00 PM
#24
Engine: 6.5L GMC
Rated Cap: 16
The stop sign. Well, my idea was to take out the screws and wiring, then the holes are to be filled with screws that have a rubber gasket that are designed for corrugated roofing. The threads will get a bit of caulk before they go in. This seems like a simple approach with very little work. I'm getting smarter as I go. SO much work. So much still to do. My list keeps growing the deeper I get into this.
10-10-2016, 06:06 PM
#25
Coachwork: Collins
Chassis: E450 Ferd
Engine: 6.0L Diesel
Rated Cap: 20 window lickin Jeffies
Liberace was THE MAN!
And this would be his bus
10-11-2016, 09:21 AM
#26
BTW...My bad! Floetrol is indeed for latex paint. Penetrol is the variety for oil based. Sorry 'bout that. Both are "flow" control products.
10-11-2016, 09:36 AM
#27
what does it do? help the paint to not run?
10-11-2016, 10:05 AM
#28
I wish! No, but it does improve the flow. Goes on smoother and with less drag when using a brush or roller. Also helps when spraying to aid adhesion and helps prevent corrosion. Good stuff. I've used it for decades.
Hingst's Sign Post: Penetrol Paint Conditioner
10-11-2016, 12:02 PM
#29
Year: 2005
So do you use the Penetrol in addition to the acetone, or in place of it?
10-11-2016, 03:16 PM
#30
Penetrol is strictly a conditioner. Whatever thinner you use, go by the ratios recommended by the paint maker.
10-30-2016, 10:03 PM
#31
How will these paint suggestions hold up in Arizona? The unrelenting sun and searing heat kills all automotive paint here. Every car more than a few years old has peeling clearcoat and oxidized paint. Horizontal surfaces are affected much more than vertical surfaces. I've read that white paint is the most resistant to UV, so I will probably paint my entire bus white except maybe the bumpers and the side impact strips. But I'm still wondering what type of paint is best to resist the UV.
10-31-2016, 07:27 AM
#32
Acetone and Mineral Spirits are 1/2 the cost of Lowes at WaLMART.
11-12-2016, 04:13 PM
#33
Engine: T444e
So we are wanting to use a white Rustoleum in a sprayer. Is that feasible, and which additives/ratios do we need? Do you guys remove all the fixtures (mirrors and such) before painting?
11-12-2016, 07:59 PM
#34
Engine: T444e
Originally Posted by AlleyCat67
This is the ratio that was given a few posts back:
So, by my math, that would be 12 oz of acetone and 8 oz of hardener (the whole can, if you use what was pictured) per gallon of paint.
How much would this differ if we were wanting to spray?
11-12-2016, 08:59 PM
#35
for arizona Id paint the roof with Bus-Kote or something similar.. its made for UV as well as has heat reflective properties too...
ive been told in any crazy sun state that lighter colors are better off for resisting UV than darker colors.. part of it may also be the temperature the paint reaches when its a darker color... paint is like anything else only so hot it can get before it begins to detiorate.. the darker colors get physically hotter in the sun.. when the ambient temperature is already 120 degrees that makes for one hot surface..
11-13-2016, 06:31 AM
#36
Just follow the instructions on the can.
11-13-2016, 07:46 AM
#37
Engine: T444e
Thanks EastCoastCB. Can anyone tell me a comparable product from a brand other than Majic? That one seems hard to find in my area.
11-13-2016, 08:32 AM
#38
https://www.amazon.com/Valspar-4625-.../dp/B000LNY1MY
11-15-2016, 08:36 AM
#39
Engine: T444e
This
and this
and last (but not least) this:
Got me this:
(Hi Mom!)
I rolled the top (almond) and sprayed the green. I mixed green and silver and black to get this metallic green color. You can't roll metallic. If you want to roll it, I'd thin the paint about 10% w/ Acetone, and mix the hardener about 15:1. And use a 1/4" knap roller.
Again, you can't roll metallic. It will look swirly and blotchy and like absolute sh!t. But you can roll solid colors with a short knap roller and have it come out pretty nice, especially on vertical surfaces.
Nice work! How many coats is that?
11-15-2016, 09:37 AM
#40
Coachwork: Collins
Chassis: E450 Ferd
Engine: 6.0L Diesel
Coats? I dunno. I painted it twice; first time it came out a fruity green that would get me noticed in the Pride parade. Used about 3 qts then. A day later I mixed a new (darker) batch of 6 qts and used about 5 of that...so it's got about 2 gallons of paint on it. I went around the bus until my arm wouldn't hold the spray gun up.
