Old 01-04-2023, 03:07 PM   #1
Windows
I would like to replace some of my bus windows with house windows. Would it be ok to cut out one or two metal studs?
Monroe32 is offline   Reply With Quote
Old 01-04-2023, 06:18 PM   #2
Chassis: Ford E450
Engine: V10 Gas
The windows really should be tempered glass, so I recommend RV windows, not residential. Additionally, residential windows are not necessarily going to hold up as well as RV windows due to vibration. Having said that, some here have used residential windows and report no issues. Aren't you concerned they might not have the aesthetic appeal? (translation: would they look stupid on a bus?).
Great question about chassis structural mods. I'll let others with roof raise experience chime in on whether removing one or more of those might compromise integrity or impact rollover safety.
Old 01-04-2023, 10:16 PM   #3
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
ol trunt's windows
Welcome to skoolie.net, Monroe32.
You gotta check out
ol trunt's windows. All of his posts, really. A true Master...
Additional photos & details here:
www.skoolie.net/home-windows-on-bus
Hopefully, he will see this thread & let us know how they're holding up. Last I heard, all good, no fog in-between.
...Meanwhile
Cutting a rib? Idk why not. Not two in a row, every other...
What sort of bus do you have, Monroe32?
Old 01-05-2023, 12:58 AM   #4
Thank you. That’s really nice and clean looking. I have a 2001 Thomas Built. What about you?
Old 01-05-2023, 07:23 AM   #5
DeMac's Avatar
Engine: 466ci
Rated Cap: 90
User Ctrl Panel
We have an IC RE300. The details are located in my User Profile, to the left of this paragraph.👈 The Registry link (underlined) contains photos and detailed descriptions.
You too, can add your information to your User Profile by clicking on [User CP], top of each page, then select [Edit Your Details] from the menu.
Selecting [Add Vehicle] will create a Registry file, where we're able make periodic updates, as our builds progress.
Is your Thomas a Van, Dognose or Flatnose?
Old 01-14-2023, 03:48 PM   #6
I used resi windows, did a roof raise and only cut one beam for a bedroom window in the loft area. All the others I ordered to fit in the existing width.
BussBry is offline   Reply With Quote
Old 01-14-2023, 08:21 PM   #7
That looks so cool. May I ask what you used for the door?
Old 01-14-2023, 09:32 PM   #8
It is a Larsen security storm door from Lowe’s. It fit perfect in the previous frame.
Old 01-14-2023, 09:39 PM   #9
It is a Larsen security storm door. It fit perfect in the previous frame.
Old 01-14-2023, 10:08 PM   #10
That’s awesome. Thank you.
Old 01-18-2023, 09:57 AM   #11
Chassis: Ford E450
Engine: V10 Gas
Very clean look.
Old 03-31-2023, 11:35 AM   #12
I wanna use a storm door for my bus too!! 😊 so cool to see someone else doing the same thing!
sigreddasparks is offline   Reply With Quote
Old 03-31-2023, 02:33 PM   #13
a Storm door at 65 MPH? you ever seen what happens when one of those shatters? thin metal frames that bow and such.. they Look wonderful but surely arent made to be primary doors..
Old 03-31-2023, 02:59 PM   #14
My bus doesn't even go 65mph lol
Old 12-11-2023, 03:18 AM   #15
@drift hunters I would like to replace some of my bus windows with house windows. Would it be ok to cut out one or two metal studs?
The first option is to remove and reseal every single bus window (and you still may have leaks).
theodoremerritt is offline   Reply With Quote
Old 12-11-2023, 09:27 AM   #16
Its a secure storm door, membrane in between sheets of glass, cannot break through it. 2 metal hooks latch into the frame of the base when closed. This door is going no where, The sales video is a guy wailing on it with a sledge hammer, the glass cracks but no entry.
