Old 11-01-2017, 08:47 AM   #221
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
At the shop now...
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 11-01-2017, 08:48 AM   #222
Congrats man!
Wear A Mask- Stop the Spread!
Old 11-01-2017, 11:09 AM   #223
Chassis: Thomas
Engine: CAT 3126
My Build Thread:
Old 11-01-2017, 11:27 AM   #224
Originally Posted by Twigg View Post
The best result would probably come from doing both. On a flat highway, the lower geared overdrive of 6th would help.
I can't suggest how you can change the programming without Allison helping, which, for reasons only they understand, requires the consent of BB.
I'm sure there are techs out there who could do it, but I don't know any. If you find one, don't publicise their details, but do share them if requested privately
I have put about 1000 miles on the bus driving interstate highways. It does good. I can run 67mph all day long. I don't need to go any faster. I would like to drop the RPMs a bit at highway speeds though. I suspect that, with the way I use the bus, if I did both I would rarely use 6th gear.
Christopher: if you take the class, I am sure that there will be a few of us that would be most happy to contribute to your education fund in exchange for programming.
Old 11-01-2017, 11:39 AM   #225
Chassis: Thomas
Engine: CAT 3126
OK I have to share a little bit more of the update. After all of this was done I went to ask how much I owed them. The technician had quoted me 150 but it turned out to be a lot more involved since there were multiple sessions and going back-and-forth with Allison. I was expecting it to be may be a little bit more than what they quoted but he said I didn't owe them anything! I couldn't believe it and it completely made my day which was also already going well! To cap it all off during the drive home I got a text back from the company doing the foam and they were willing to knock $200 off of their earlier quote for applying the two-part foam. I'm having a good day!
My Build Thread:
Old 11-01-2017, 01:01 PM   #226
GOOD ON YA!
Please share any extra that you can(-:
1olfart is offline   Reply With Quote
Old 11-01-2017, 03:25 PM   #227
Chassis: Thomas
Engine: CAT 3126
Congrats man!
Thanks! Big relief!
My Build Thread:
Old 11-01-2017, 05:16 PM   #228
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Well done. It was a little work, but worth it.
Old 11-01-2017, 05:45 PM   #229
joeblack5's Avatar
Year: 98
Congrats, did you have the impression that the communication with allison was required because the tech was inexperienced or did he need to give the allison folks the pre 6 gear parameters in the TCM ?
later J
Old 11-01-2017, 05:57 PM   #230
kick ass!!!!now that i love to see!!! hacking and unleashing the potential of your bus!!!!! good work!!
Old 11-01-2017, 06:55 PM   #231
Chassis: Thomas
Engine: CAT 3126
later J
I have a lot better understanding of the whole process now than I did going into it. It is essentially about three things: the first is having the correct computer interface for the TCM module. I'm pretty sure it is proprietary Allison hardware. The second is the CIN code. You have to pull the CIN code that pre-exists on the TCM and send that to Allison. They send you back a new CIN code which is then downloaded in to the TCM. Once the TCM knows what CIN it has, it has to request the data that corresponds to that to update the shift programming. A laptop queries Allison's database and pulls down the necessary data and sends it to the TCM. I still may not fully understand the process but I think it's unlikely you would be able to do it with out either being part of Allisons ecosystem or reverse engineering their software.
My Build Thread:
Old 11-01-2017, 06:57 PM   #232
Chassis: Thomas
Engine: CAT 3126
And I got to tell you I'm still blown away that the guy did it for free! I can't tell you how much that whole experience made my day!!
My Build Thread:
Old 11-01-2017, 06:59 PM   #233
Chassis: Thomas
Engine: CAT 3126
If there is any Silver-lining at least you already have a better gear ratio then I do in mine. With my 6 to 1 rear end I couldn't really even make it up to more than about 63 without winding the motor out much faster than it really should cruise.
My Build Thread:
Old 11-01-2017, 08:37 PM   #234
Chassis: Thomas
Engine: CAT 3126
4 Curious Georges' 2001 Saf-T-Liner
What an eventful day! I went to fill it to see what my new gas mileage might be. I went ahead and filled the tank all the way for the first time. It took about $215 worth of diesel fuel. I ran out to Lowe's to pick up a load of lumber in the bus and noticed when I got there that it was leaving a puddle of diesel. Actually probably not a puddle but it was definitely dripping. After taking a look at the situation I realized it doesn't seem to be leaking while the vehicle is still, so it must have to do with the sloshing and probably the filler neck or hose. Do any of you have experience on troubleshooting a scenario like this? Realistically I only think it leaked a few ounces of diesel but it makes your heart drop when you see all that Fuel that you put in starting to come out and possibly cause a a major issue as well as spill out all that expensive fuel.
My Build Thread:
Old 11-02-2017, 09:56 AM   #235
Chassis: Thomas
Engine: CAT 3126
Anybody have experience fixing leaky fuel tanks?
My Build Thread:
Old 11-02-2017, 05:17 PM   #236
Did you run the pump wide open when filling or fill slowly? Pumping diesel is different than pumping gasoline. I think you may just have expansion problems if you filled it right to the brim.
Sure wouldn't hurt to snoop around and crawl under to see what the situation is. Maybe your tank has a hole near the top somewhere alsoo so you could burn the fuel out or pump some out into another can.
Old 11-02-2017, 05:42 PM   #237
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
OK, I'm jealous. I, too, have an MD3060. How do I get a 6 on my dash?
Old 11-02-2017, 06:05 PM   #238
Chassis: Thomas
Engine: CAT 3126
Have you read the thread this far?
My Build Thread:
Old 11-02-2017, 06:06 PM   #239
Chassis: Thomas
Engine: CAT 3126
It was a slow pump so I'm sure if filled to full. Took 93 gallons. Gonna pull the access panel as soon as I can and see what I can find.
My Build Thread:
Old 11-02-2017, 06:08 PM   #240
Chassis: Thomas
Engine: CAT 3126
We can talk offline if you want. I may have some useful advice.
My Build Thread:
