11-22-2017, 08:10 AM
#261
Chassis: Thomas
Engine: CAT 3126
Just binged Ian's vlog from start to finish! What a journey! Encouraging and scary both! I am behind schedule for a summer 2018 trip that I have planned with my family. What words of wisdom and encouragement would you give towards still doing a good job, not taking forever, and not getting discouraged with the size of the challenge?
11-24-2017, 10:28 AM
#262
Chassis: Thomas
Engine: CAT 3126
So I have been out if town and away from the bus, but have been able to devote some time to planning. This may be hard to decode and I certainly didn't use any common conventions and symbols, but if any of it makes sense to anybody I'm interested in feedback.
11-24-2017, 03:29 PM
#263
Chassis: Thomas
Engine: CAT 3126
Planning on installing a 2500W AIMS inverter/charger. Trying to decide if it's worse to have the inverter in the bedroom or to run a cable about 15 feet to another part of the bus. It seems like I would have to go with a massive cable to support the amperage at 12 V. I'm not really crazy about the idea of sleeping in the same room as a big inverter though. Am I just being paranoid? What have you guys done?
11-24-2017, 03:41 PM
#264
Chassis: Saf-T-Liner MVP ER
Get it as close to the house batteries as you can. Run the 110V as far as you like.
11-25-2017, 08:16 AM
#265
I haven't been on here in a while. I love the colors and the progress!
11-25-2017, 02:14 PM
#266
Been sleeping over a 2000W for years; folks did it before me. *Shrug* we're putting ours below the bed in the new bus.
Sent from my XT1575 using Tapatalk
11-25-2017, 05:45 PM
#267
Chassis: Thomas
Engine: CAT 3126
That's the conclusion I am coming to. Wiring is just too fat and expensive @ 12V as distance increases.
11-25-2017, 05:46 PM
#268
Chassis: Thomas
Engine: CAT 3126
Thanks! I feel like I'm not getting anything done...but I am, it is just slower than I want.
11-25-2017, 05:48 PM
#269
Chassis: Thomas
Engine: CAT 3126
Yeah, when I think about it I will generally not be running the inverter while sleeping. Generator or shore power will be the main night time strategy.
11-25-2017, 07:17 PM
#270
What would it matter if you were running the inverter?
11-25-2017, 07:25 PM
#271
The one item that runs 24/7 is the fridge.
It is worth having a small, dedicated inverter just for the fridge. It won't be too expensive for a 3-400W Sine Wave inverter, and the cable demand to locate it close to the fridge will be modest too. It might even let you go one size down on your main inverter (the ones that cost the real money).
11-25-2017, 10:06 PM
#272
Chassis: Thomas
Engine: CAT 3126
That's interesting. Basically make any 120v fridge 12v capable by adding a dedicated inverter. The Aims is a charger too so when there is mains power the 12v side automatically is powered/charged as well.
11-26-2017, 10:15 PM
#273
Chassis: Thomas
Engine: CAT 3126
Purged my air tanks and green oil sprayed out. Normal? Do I need to top it off to replace what sprayed out? Seemed to be no water...
11-27-2017, 09:55 AM
#274
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
That's water from the ambient air that was compressed and introduced into the rest of the air system, only to settle in the air tank. The reason it's green is due to the copper components in the air system.
An air system is designed to never have ANY liquid in it.
Hope this helps.
M
11-27-2017, 12:24 PM
#275
Chassis: Thomas
Engine: CAT 3126
Hope this helps.
M
Wow! Thanks! I figured it was lubricant for the compressor like the Ester oil in an AC system. It sure seemed like oil. Is there any way of could be?
11-27-2017, 12:30 PM
#276
That's air compressor mayonnaise, and it's wonderful!
Robin
Nobody's Business
11-27-2017, 01:06 PM
#277
Chassis: Thomas
Engine: CAT 3126
It didn't seem emulsified, just like oil. Should I be concerned?
11-27-2017, 03:23 PM
#278
Just keep an eye on it over the next few purges. You'll have a better idea then.
11-27-2017, 03:35 PM
#279
the air compressor almost always pushes a little oil into the tank, along with moisture.. most often the air dryer catches 99% of it and expels it.. if you dont have an air dryer much more ends up in the tank.
11-27-2017, 10:35 PM
#280
Chassis: Thomas
Engine: CAT 3126
Making a little progress. Took forever to rip these 2x4s to create a framing lip for the foam to fill in against. Probably would have been easier with a table saw but a circular saw had to do. Still not completely finished bit one step closer.
