11-28-2017, 09:57 AM
#281
Nice job using a circular saw I must say!
You have done a pile of work there, will pay off though in the end.
11-28-2017, 12:53 PM
#282
Chassis: Thomas
Engine: CAT 3126
Thanks! I still need to figure out the best strategy for cross pieces, but one thing at a time.
11-28-2017, 12:55 PM
#283
Chassis: Thomas
Engine: CAT 3126
Well for better or for worse I just purchased this.
https://www.iaai.com/Vehicle?itemID=...&RowNumber=231
$350 + fees.
Now I gotta drive to get it in the next few days. Hopefully will have at least that $ worth of stuff!
11-28-2017, 01:17 PM
#284
Great buy for all that equipment. Is it towable or need a wrecker to get it home?
11-28-2017, 01:21 PM
#285
Chassis: Thomas
Engine: CAT 3126
If there is nothing wrong with the suspension I can tow it. Unfortunately the picture don't show. Usually they state if there is undercarriage damage and this one didn't say anything, but who knows. In one picture the angle that the driver's side wheel is at looks askew, but I'm hoping it is an optical illusion based on the fact that the whole trailer is deformed.
Planning to bring lots of straps and if need be I'll just put a new axle or spring pack under it to get it home.
11-28-2017, 01:34 PM
#286
If a trooper stops you just tell him you are going on vacation.
11-28-2017, 02:04 PM
#287
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
I'd say I let my wife try backing-it into a spot.
11-28-2017, 08:46 PM
#288
Chassis: Thomas
Engine: CAT 3126
I'm sure those would be well received by both my wife and the trooper!
Hey does anyone want my old hatches? They aren't in great shape, but if someone is trying to make them work they could have some helpful parts.
11-28-2017, 10:51 PM
#289
Chassis: Thomas
Engine: CAT 3126
Did a little cable sorting and deletion.
Also got cleaned up for the spray foamers. Just need to mask now.
11-28-2017, 11:14 PM
#290
I did that taping myself too. What a pain, then the cleanup mess.
Did they tell you about using duct tape on the ribs?
Robin
Nobody's Business
11-29-2017, 07:53 AM
#291
Nice job on getting it all cleaned up and ready for insulation!!! make sure everythoing you want still works before they shoot it full of foam!..
christopher
11-29-2017, 01:40 PM
#292
Chassis: Thomas
Engine: CAT 3126
No, what is the story with duct tape?
11-29-2017, 01:44 PM
#293
Chassis: Thomas
Engine: CAT 3126
christopher
Good thinking! I put in all new marker lights and everything seems to work. Hmmm...I guess that I haven't verified that the mirror heaters work. What else am I forgetting? Maybe I should fix the main door sensor so it doesn't beep when I park with the door open too...
11-29-2017, 02:38 PM
#294
My foam guy said to get about 5 rolls of cheap duct tape to put on the rib surfaces on the inside. That allows you to pull off the tape after the spray job and have clean rib surfaces. Time saver during cleanup.
Cleaning up foam overspray is pretty tiresome. Any exposed surface will likely get overspray foam on them if they're not well covered with plastic sheeting or whatever you're using.
I skipped taping off a few areas thinking the guy would never get close enough to that area to cause any problems with overspray. I left a small patch of the floor and some hand rails exposed which I regretted. There was quite a strong airflow from the foam gun, not to mention the airborn foam particals that will even stick to your eyeballs if you're trying to watch the guy spray. Some of the tapeing was blown out of position by the air gun.
If I insulate another bus I'll likely use foam panels and canned foam for the small areas.
Robin
Nobody's Business
11-29-2017, 02:44 PM
#295
I'll be using foam board and filling in with a DIY foam kit. I'm just not a fan of "great" stuff.
11-29-2017, 03:06 PM
#296
I'll appreciate seeing how you work that. My foam job was a major pain in the caboose.
Robin
Nobody's Business
11-29-2017, 03:10 PM
#297
I'll mask everything I don't want foamed.
I'll do it myself so no one can be blamed but myself if I screw up.
Or maybe I'll just put as much foam board as I can and call it a day. That's already gonna be better off than 90% of the builds out there where they're leaving the puke mats and fiberglass in it.
I'll see how I feel when I get this one gutted! lol
11-29-2017, 10:13 PM
#298
Chassis: Thomas
Engine: CAT 3126
Not finished masking but don't my best to take your advice and be thorough.
11-30-2017, 01:16 PM
#299
Chassis: Thomas
Engine: CAT 3126
Well, this just happened!
11-30-2017, 03:37 PM
#300
Year: 86
Chassis: Ford B700
Engine: 8.2
Hell yeah!
Merry Christmas to yall
