Old 01-26-2018, 09:16 PM   #601
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
I thought this was an interesting option for bus.
Window A/C Unit That's Less Than 6 Inches Tall
That looks very cool! Did they say when they plan to come to market?
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 01-26-2018, 09:20 PM   #602
Chassis: Thomas
Engine: CAT 3126
Tack welded and ready for a test fit.
My Build Thread:
Old 01-26-2018, 09:26 PM   #603
It just says Spring of 2018 to the USA/CAN.
Old 01-27-2018, 08:08 PM   #604
Chassis: Thomas
Engine: CAT 3126
Looks like it should fit!
My Build Thread:
Old 01-28-2018, 12:02 AM   #605
Chassis: Thomas
Engine: CAT 3126
Finished welding the first one and made a 2nd to match!
My Build Thread:
Old 01-28-2018, 12:53 AM   #606
Robin97396's Avatar
That's looking good the way you're hanging it there.
Nice job of taking pics too.
Robin
Nobody's Business
Old 01-28-2018, 02:18 AM   #607
David,
Any rubber dampers underneath the unit? Now would be the time.
Up at the top beneath the floor...are you welding to the cross members and the floor? Trying to think where you start tacking the way the pic shows, but I don't see where it will be welded permanent as there seems to be no grinding done yet.
Strong frame otherwise, just hope it has some wiggle room for dampening the unit vibration.
Old 01-28-2018, 09:52 AM   #608
Chassis: Thomas
Engine: CAT 3126
Originally Posted by BlackJohn View Post
David,
Yes Iím planning on using rubber isolators. The cage is plenty tall enough to accommodate the added height. I plan to have it sit on rubber feet as well as be clamped down on top with rubber isolators.
Iím planning on bolting it to the bus rather than welding it to the bus so it can be removed if necessary at some point in the future without cutting.
My Build Thread:
Old 01-28-2018, 01:52 PM   #609
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
Looking good.
The only other thing I would like to suggest is some expanded metal to provide road debris protection or rubber flap protection if you happen to have a tire come apart.
Old 01-28-2018, 02:37 PM   #610
Chassis: Thomas
Engine: CAT 3126
In progress...
My Build Thread:
Old 01-28-2018, 02:38 PM   #611
Chassis: Thomas
Engine: CAT 3126
Originally Posted by Jolly Roger bus 223 View Post
Looking good.
Great idea!
My Build Thread:
Old 01-28-2018, 02:48 PM   #612
Year: 86
Chassis: Ford B700
Engine: 8.2
You don't need to add extra framing to use the expanded metal.
You can actually bend the corners in the expanded metal to make a age to fit.
If you want to use that idea. Let me know I can explain.
Have fun
Old 01-30-2018, 11:07 PM   #613
Chassis: Thomas
Engine: CAT 3126
Canít remember who, but got the idea for the drill press from someone on here. Works like a charm!
Frame is super solid once bolted in. Too bad it has to come out again to get painted...
Everything is labor intensive it seems...
My Build Thread:
Old 01-30-2018, 11:08 PM   #614
Excellent fix. I like the way you think!
Old 01-30-2018, 11:10 PM   #615
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
I can think of several dentists that might actually take you up on that idea......
M
Firearms stand next in importance to the Constitution itself. They are the American peopleís liberty teeth and keystone under independence. ó George Washington
M1031A1 is offline   Reply With Quote
Old 01-31-2018, 07:37 AM   #616
your units didnt have rubber isolaters in the box? all of mine came with them, they were part of the shipping materials but were designed to be used in the final installation. ..
this install is looking kickass just leave PLENTY of clearance for connecting your lines.. you cant have sharp corners.. they will kink.
Old 01-31-2018, 12:08 PM   #617
Chassis: Thomas
Engine: CAT 3126
Yep, they did come with isolator! Thanks for the encouragement! Everything is so simple in concept and turns into a can of worms in execution! thankfully I think it should be plenty of room because I donít know how I would get more if I needed it.
My Build Thread:
Old 01-31-2018, 09:32 PM   #618
Chassis: Thomas
Engine: CAT 3126
This is all made a bit more complex by the fact that Iím trying to install two of these. The one closer to the back of the bus which is going in just in front of the rear axle has plenty of room around it. The one that Iím installing in the front is going more or less right underneath the driver. The one in front I think will have enough room for the Lines and everything but itís a pretty tight space to work in and it has a lot of odd complexities with other components that are installed. After a lot of difficult rolling around in the dirt and holding heavy things on awkward spots on my body I was finally able to get all of the appropriate adjustments made and holes drilled. Iím finally ready now to clean prep and paint everything. Then the final install. If Iím lucky I may be able to get that done by the time the weekend is over. Then if I can find somebody who can evacuate the lines I should be really close to having working heat and air from these heat pumps.
My Build Thread:
Old 01-31-2018, 09:38 PM   #619
trying to think when im going to florida again.. I just lleft nashville and am in columbus now.. I have the vacuum pump, gauges and adapters to evac and charge those lines.. the final charge out needs to be done wit hthe units running but the evac just needs the lines connected to the indoor and outdoor units
Old 02-01-2018, 12:45 PM   #620
Chassis: Thomas
Engine: CAT 3126
That would be amazing!
My Build Thread:
