02-20-2018, 10:57 PM
#741
Chassis: Thomas
Engine: CAT 3126
02-20-2018, 11:53 PM
#742
Chassis: Thomas
Engine: CAT 3126
Originally Posted by Twigg
They make excellent accent lighting, but keep some spares around as they have a bad habit of "not lighting" after a while.
I’ve seen that as well. I teach a class on lighting for film and photography and I’m pretty picky about light quality. I searched for a while to find these and am really happy with the color quality of them. I guess time will tell regarding longevity. I think most issues with LEDs comes from heat buildup so ventilation is key.
02-21-2018, 08:19 PM
#743
Chassis: Thomas
Engine: CAT 3126
I installed the 50 amp power inlet tonight.
Since the inlet doesn’t install with butyl tape it has just some foam backing I decided it would be worth it to spray some primer on the cut metal to head off any rust.
I really like the inlet that I purchased it seems easy to install and robustly made.
So far everything works great. I did a wiring set up with it where I double tapped the ground, neutral, and one hot leg as a permanent feed to my inverter.
It simultaneously feeds a female 50 amp receptacle with (4) single conductor six gage welding wire and my inverter (10/3 SOOW) which in turn charges the house batteries and energizes the 12 V system.
Sorry, this is all super difficult to try to explain. I’ll try to lay out a diagram that shows what’s going on. At the end of the day my goal was to be able to get full 50 amp service into the bus but then to be able to alternately supply both halves of the hot 120 V panel from a single hot leg when I’m on my inverter. The other thing that I had to ensure was that even when shore power went straight to my panel I still was sending power to my inverter so it could charge my house batteries and energize the 12 V system. It would really suck to have my 50 A system up and running but then run my house batteries dead with the fantastic fan or furnace blower.
02-21-2018, 09:43 PM
#744
Chassis: Thomas
Engine: CAT 3126
The coves are not properly installed and the lighting is temporary but I just dropped the ribbon in to the channel to see what it might look like.
I have to admit I’m a little bit giddy. Having light in the bus suddenly makes everything totally different.
02-21-2018, 09:50 PM
#745
You do nice work. That's a nice way to do the lighting.
Robin
Nobody's Business
02-21-2018, 11:06 PM
#746
Ya...love the indirect lighting approach. Lookin' good!
02-22-2018, 06:39 AM
#747
Chassis: Saf-T-Liner ER
Engine: Cummins ISC 8.3 Allison MD3060
I am enjoying reading through this build. You're doing an awesome job, thank you for sharing as it will certainly help me as I get into mine.
Keep up the great work!!
James
02-22-2018, 11:24 AM
#748
Chassis: Thomas
Engine: CAT 3126
Thanks guys! I try. It’s easy to make your work but good in pictures on the Internet. I try to always do good work but there’s definitely some parts of this build I would not want to post online!
02-22-2018, 12:06 PM
#749
Chassis: Thomas
Engine: CAT 3126
Got one of the units up and running! I have to say they said that these units were quiet that is an understatement. It’s taking a lot of work to get to this point but I couldn’t be happier with how this unit is performing and how the install in general seems to be working out.
The unit is cooling very well and even has features that I didn’t realize in addition to being both heat and air conditioning it also has a dehumidifier mode that leaves the ambient temperature the same but removes the moisture from the air. It had not occurred to me that units like this might have that feature but I would see it as being highly desirable in a bus environment where you may have condensation issues.
I did a check to see how much power it was using and I’ll need to do further testing to see how much it uses in various conditions but a while it was running on its initial cool down it was using about 650 W.
I ran it off my house batteries alone for about 5 to 10 minutes and it ran without any issue.
On the other unit we are trying to figure out if there’s a problem with the unit or a problem with the technicians equipment. It holds a nitrogen charge just fine but it went from holding a 600 µm vacuum to not even getting below one atmosphere of pressure within the course of just a few minutes. It seems possible that the vacuum pump is just going out. He left it with the nitrogen charge about 200 psi and is going to come back this weekend and see if it’s still holding that charge. If it is still holding the charge then will use a different vacuum pump to evacuate the system and then that system should hopefully be ready to run.
The whole bus cools pretty effectively with the single unit but it is noticeably colder at one end of the bus then the other especially while the bus is parked on somewhat of an incline.
02-22-2018, 12:42 PM
#750
Chassis: Thomas
Engine: CAT 3126
Does this make any sense? I hope so...
02-22-2018, 10:50 PM
#751
Looks good except I would have the right guard pull and cover the middle.
--- John Madden
02-23-2018, 04:39 AM
#752
Sweet that you got the AC up and running!!!!!!!! Congrats!!! I love these type units, mine here in Ohio were on heat yesterday. You lucky ducks to be using AC!!
I loved the led lights! I use the philips all over my house. Strip and bulbs. I create complete interior scapes just by changing the colors intensity and location of lights, I can only imagine what you can do in a bus!!!!
02-23-2018, 09:42 AM
#753
What are you using for roof material? How did you get that nice curve above the windows without cracking? Thanks!
02-23-2018, 10:25 AM
#754
1/4" thick luan or plywood, bends pretty easily at that thickness.
02-23-2018, 10:41 AM
#755
Chassis: Thomas
Engine: CAT 3126
It is 1/8” luan style panel from Home Depot. If you watch Ian Robinson’s vid blog he made a jig to help curve them. I didn’t find that to be very helpful, but with the right technique I was able to bend them by hand fairly easily. There is kind of a trick to it though, it’s hard to explain, but you get a feel for eventually.
The most important keys to not breaking it are getting it damp with a spray bottle and letting that sink in for a few minutes before you start the bendand making sure that it’s warm. Back in the super cold snap that we had around New Year’s I tried bending some pieces and they just snapped immediately. I had to get everything warmed up and wet before I could bend them into place.
02-23-2018, 12:02 PM
#756
Ok, I did it the hard way. I put what I thought was 3/4" ply on my ceiling. That’s the hazards of shopping at Lowes without my glasses. I wanted to be able to attach things to the ceiling and have enough strength there to support whatever I might need in the future. Yeah, overkill maybe. Also if I put partitions up I don't have to hit a rib for it to be a strong attachment.
What I've got is just like a subfloor, half inch insulation followed by 19/32nds ply up the walls and across the ceiling.
I put full sheets right down the middle of the ceiling and it wasn't that hard to get them to bend to the ceiling using a hilift jack to hold them in place. I cut strips for the curve near the wall.
Yeah, I know. This method leaves a relatively ugly unfinished looking bus. It's insulated and has a subfloor throughout, so imagine how easy it would be to attach any aesthetic covering over the ply surfaces or to attach framing.
Robin
Nobody's Business
02-23-2018, 12:37 PM
#757
Chassis: Thomas
Engine: CAT 3126
Wow! Well that would sure make some parts of the build much easier! I can’t afford to lose any more headroom so I went as thin as possible.
02-23-2018, 01:52 PM
#758
Yeah, lucky for me I've shrunk about 2 1/2" over recent years. I never did insulate my floor, and my feet have been cold for a number of months now. I'm likely insulating my floor soon. I'll crouch if I have to. Learn to walk with my knees bent.
Robin
Nobody's Business
02-24-2018, 09:58 PM
#759
Chassis: Thomas
Engine: CAT 3126
Wired a couple of 12v switches tonight. They have 3 blades, one of which is ground to allow the indicator light to work and two more for line and load which are interchangeable. It has been fun planning out how to run wiring for DC vs AC. Getting the feel for how the crimping tool works.
I think I’m massively overdoing the wire sizes, but I’ve got the wire...
Turned off. They came in a pack of 15, 3 of each color: red, green, blue.
Both sides lit. Ribbons just temporary.
Fridge arrived yesterday. Fits perfectly where we planned. 7.3 cu/ft. When compressor is running it uses 100 Watts according to my test. We’ll see what the duty cycle is.
I have a very nice 4.5 cu/ft RV fridge that runs off of LP or AC that I need to sell. It came from the camper that I recycled after a tree fell on it. Just a little too small for us. It is a 2015 model year and still sells on Amazon for about $1k. I know I won’t get that for it, but they have value for sure.
Hopefully will get 2nd HVAC unit running tomorrow.
02-25-2018, 03:13 PM
#760
Chassis: Thomas
Engine: CAT 3126
I am having too much fun!
Got both hvac units running!
My inverter can run them both on high heat with the fridge going as well.
Off batteries the inverter registered 78%, which converts to 1950 Watts or 16.25 amps @ 120 volts, 162.5 amps @ 12 volts (plus inverter inefficiency)
Then I decided to break out the generator and see how it would do.
Fired up great and in power save mode ran pretty quietly while charging house batteries, running both HVAC units, and running the fridge.
It’s an inverter unit and seems like it is sized well to my needs. It seems like the bigger you go with a generator the less efficient it is at lower output and I didn’t want to go through gasoline at too high of a rate. We’ll see how it works once we actually are using it for real but at least in test it seems just about like it’s the perfect balance between power and efficiency.
I took a serious look at the dual fuel models, but if I remember correctly propane was going to be significantly more expensive to run the unit from. It didn’t seem like it was worth the extra money to be able to run off of an alternate fuel that is more expensive. I can imagine there may be some point in the future when I’ve run out of gasoline but still have propane that I might change my mind about that!
I still have to test from a true colds tart but I’ve tested multiple times the remote control for the generator and it seems to work very well. The inverter and generator both have 15 second delay between start up and transfer of power so the process seems to be smooth every time going from inverter mode from the batteries and transferring over to the generator.
