Old 03-07-2018, 12:09 PM   #861
Chassis: Saf-T-Liner MVP ER
U-Haul sell by the gallon too.
And they will re-fill the 20lb tanks which is especially useful if yours isn't completely empty.
Steve Bracken
Build Thread
Old 03-07-2018, 08:21 PM   #862
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Finished coves.
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 03-07-2018, 10:39 PM   #863
Indirect lighting was MADE for the curved roof of a Skoolie.
LOVE it!
Old 03-09-2018, 12:19 AM   #864
Chassis: Thomas
Engine: CAT 3126
Well I’ve gotten a bit slowed down working to finish the ceiling. I must confess I really hate working with this thin luan.
Quite difficult to get good butt joints and I’m trying to finalize a trim strategy to cover them and help even out mismatches in height.
Current plan is pvc lattice. Like this.
All very fiddly.
My Build Thread:
Old 03-09-2018, 10:24 AM   #865
Chassis: Thomas
Engine: CAT 3126
Cutting in the seat belt stay.
My Build Thread:
Old 03-09-2018, 06:03 PM   #866
Chassis: Thomas
Engine: CAT 3126
This seems silly but it is working. My efforts to keep the ceiling as low profile as possible has limited my ability to create attachment points and the 1/8” luan warps easily. I’m kind of floating in this section of ceiling. Lapping the luan from above to create an attachment flange for the middle section. Then spraying great stuff above as a kind of shimming glue, then using prop rods from the floor to brace at correct height until great stuff cures.
So close to done, but not today.
Donated some blood to the bus today when a Phillips screw slipped and I got my finger pretty good with the drill. Oops.
My Build Thread:
Old 03-09-2018, 06:17 PM   #867
Chassis: Thomas
Engine: CAT 3126
This showed up.
My Build Thread:
Old 03-09-2018, 06:43 PM   #868
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
I put an 1/8" drill bit through my thumbnail and thumb today when it broke? Best way to get it out was put the drill in reverse.
Didn't lose the nail but it's got awhile with a band aid.
Looking good.
Old 03-09-2018, 11:03 PM   #869
Dizzyman's Avatar
Coachwork: Thomas MVP
Engine: Cat 3126B
Rated Cap: 20800
Originally Posted by david.dgeorge07 View Post
I decided that I would cross the bus from driver’s side to passenger side for all power at the rear of the bus rather than going through the floor or the roof. Once I made that decision it was easy to add drops for AC power in the rear end here. I don’t know if you can tell from the photos but there’s DC wiring that terminates there which will be used for reading lights.
I hadn’t thought of filling in that space. I suppose it would be possible that varmints could get in there. I’m afraid there may be quite a few places in the bus where something might be able to get in and fit. I guess I was counting mostly on the fact that spray foam isn’t super hospitable to keep them away but maybe I need to think more seriously about sealing all cracks and voids. Do any of you have build experience on having problems with these things and or ways to make sure to mitigate to them?
At least in this case and/or area I think a few beads of caulk would likely make it difficult to impossible to enter.
This is easy to use and rodent proof big time.
Www.buyxcluder.com
Dizzyman is offline   Reply With Quote
Old 03-10-2018, 11:41 PM   #870
Chassis: Thomas
Engine: CAT 3126
Looking good.
Ouch! Sounds like you got it worse than me!
My Build Thread:
Old 03-10-2018, 11:42 PM   #871
Chassis: Thomas
Engine: CAT 3126
Www.buyxcluder.com
So would you just put this on the door! Is that the idea?
My Build Thread:
Old 03-10-2018, 11:46 PM   #872
Chassis: Thomas
Engine: CAT 3126
Ready for the middle panel.
Middle panel in.
Front side panels are in and curing tonight.
Spent the rest of the evening rebuilding this box. Plenty strong but visually crooked. So frustrating on a bus where nothing is square and level. Unfortunately it doesn’t mean that you can just slap it together!
My Build Thread:
Old 03-11-2018, 05:52 AM   #873
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Trying to be clever. Does sort of work. Enough to try anyway.
Drill a hole through the side, near the top of the board you drag across the ceiling, run a bolt through it and attach a small wheel that way it moves smoother and you get a more even line.
Great idea btw!
-Doc
Old 03-11-2018, 10:14 PM   #874
Chassis: Thomas
Engine: CAT 3126
Great idea btw!
-Doc
That’s a great idea!
My Build Thread:
Old 03-11-2018, 10:19 PM   #875
Chassis: Thomas
Engine: CAT 3126
Ceiling is ready for paint.
Kitchen blank slate.
Some pex.
Roughing in the kitchen cabinets. Planning to use some free cycled walnut from a table for the counter.
Used a Kreg tool for a bunch of this. Really cool!
My Build Thread:
Old 03-11-2018, 11:45 PM   #876
Dizzyman's Avatar
Engine: Cat 3126B
Rated Cap: 20800
You can stuff it into any openings that might be a potential entrance or pathway for rodents. Full size mice can squeeze through an opening the size of a dime.
Old 03-12-2018, 11:36 PM   #877
Chassis: Thomas
Engine: CAT 3126
Most of the time my wife helps with research and purchasing, but it was nice to have her on the bus sanding this walnut sheet!
I think it’s gonna look nice!
Had to press pause for a minute when I realized I had no idea how to build a cabinet. I will not be a cabinetmaker’s cabinetmaker, but I think I’m getting the hang of it.
Tricky parts here were figuring how the kickpanel recess would work with the base and transition into the side of the oven. Oven is supposed to arrive tomorrow...
One of the pockets drilled with the Kreg tool.
My Build Thread:
Old 03-13-2018, 10:42 PM   #878
Chassis: Thomas
Engine: CAT 3126
Incremental progress on the cabinets tonight.
Stove was a no show, but hopefully will be here soon. Nice hole waiting for it in the design. Fingers crossed it is the right size.
My Build Thread:
Old 03-14-2018, 10:24 PM   #879
Chassis: Thomas
Engine: CAT 3126
What do you guys think of using a piece of ceiling sheet metal for the stove backsplash and under the microwave cabinet? (Above the stove)
My Build Thread:
Old 03-14-2018, 10:30 PM   #880
Sounds like a great idea.
I can't do it because all my panels are perforated steel, but I could use them for door panels in the cabinets.
Steve Bracken
Build Thread
