Old 03-14-2018, 11:31 PM   #881
Sounds good if it's steel, wouldn't do it if it's aluminum. Stainless would be best.
Sent from my XT1710-02 using Tapatalk
Dave in Tucson is offline   Reply With Quote
Old 03-15-2018, 12:08 PM   #882
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Oh thatís a great idea! I forgot that I have sheets of stainless that I pulled from the slide on the RV that I recycled!
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 03-16-2018, 02:33 PM   #883
Chassis: Thomas
Engine: CAT 3126
Stove finally arrived! Fits perfectly!
My Build Thread:
Old 03-16-2018, 02:45 PM   #884
Chassis: Thomas
Engine: CAT 3126
Had to detour to get my jeep running again so I could tow my trailer for supplies.
Harmonic balancer went bad and fan blades were hitting it.
Good opportunity to open the bumper up and prep for tow bar base plates.
My Build Thread:
Old 03-16-2018, 05:24 PM   #885
Chassis: Thomas
Engine: CAT 3126
More test fitting.
My Build Thread:
Old 03-16-2018, 07:32 PM   #886
How will you hold that stove in place while driving? I could see it flopping over on rough roads.
ben2go is offline   Reply With Quote
Old 03-16-2018, 07:40 PM   #887
Mgulley82's Avatar
Chassis: 40' Saf-T-Liner MVP ER
Engine: CAT 3126 7.2L
What stove is that?
Mgulley82 is offline   Reply With Quote
Old 03-16-2018, 07:51 PM   #888
Originally Posted by Mgulley82 View Post
What stove is that?
It looks like a small propane apartment range.
Old 03-16-2018, 07:52 PM   #889
Chassis: Saf-T-Liner MVP ER
If it were mine, and I'm sure David will do the same, it would be bolted, or screwed with lag-bolts, to the floor, the wall behind it and the frame of the kitchen at the side.
Steve Bracken
Build Thread
Old 03-16-2018, 08:03 PM   #890
Chassis: Thomas
Engine: CAT 3126
It comes with hardware to bolt it down.
My Build Thread:
Old 03-16-2018, 08:05 PM   #891
Chassis: Thomas
Engine: CAT 3126
Yes, LP or NG Premiere brand 20Ēw 24Ēd apartment stove.
My Build Thread:
Old 03-16-2018, 08:06 PM   #892
Chassis: Thomas
Engine: CAT 3126
Yes. In the works. I am still trying to figure out how to keep the burner grills from rattling.
My Build Thread:
Old 03-16-2018, 08:08 PM   #893
So when we had that problem, we just popped a tea-towel under them for traveling.
Steve Bracken
Build Thread
Old 03-16-2018, 09:46 PM   #894
Dizzyman's Avatar
Coachwork: Thomas MVP
Engine: Cat 3126B
Rated Cap: 20800
Finally finished getting the coolant loop out of the rear passenger compartment. It wasn't much fun, but got easier when I found an access panel with four screws. It allowed me to get right at what I needed to!
Sent from my SM-N900P using Tapatalk
Mine is a 99 RE Thomas and removing the rear heater is next. What was involved in removing the unit and coolant lines? Through my access panel I see one manual valve not 2. Iíll have to look for the panel to remove you refer to. Any info will help!
Dizzyman is offline   Reply With Quote
Old 03-16-2018, 09:56 PM   #895
Mine only has one valve through that panel.
It has two others but you have to get underneath to find them. One is a handwheel-type like the first one and the other has a lever.
I haven't traced the lines (this weekend), so I don't know why there are three or what they all do.
I removed 4 passenger heaters and left the front heater/defroster in place. That means I pulled around 70 feet of rubber pipe out of the bus, and am splicing the good lengths to reconnect the heater but running the coolant under the bus.
Steve Bracken
Build Thread
Old 03-16-2018, 10:23 PM   #896
Dizzyman's Avatar
Engine: Cat 3126B
Rated Cap: 20800
I only have 1 heater in the rear then the front console and defrost. I am not off till Tuesday so will try to trace lines then. I wonder since it is RE if the coolant first goes through the rear heater on the way to the front or if the front is ďplumbedĒ separately?
Old 03-16-2018, 10:34 PM   #897
Chassis: Thomas
Engine: CAT 3126
My pics show where the send and return from the engine pass thru into the interior of the bus. The lines probably run to one heater, then thru floor just behind drivers seat and to the drivers heat and defrost.
Work either from the back forward or from the front back (what I did). Have buckets ready to catch coolant.
My Build Thread:
Old 03-17-2018, 08:53 AM   #898
Dizzyman's Avatar
Engine: Cat 3126B
Rated Cap: 20800
Appreciate it!
Old 03-17-2018, 11:48 AM   #899
I sat the hose-end of the heaters in a cat litter tray before disconnecting the pipes. That caught just about everything then I filtered the good-looking coolant into empty 1-gallon milk jugs for use later.
Very little spilled.
Steve Bracken
Build Thread
Old 03-17-2018, 12:06 PM   #900
Supa Dave! He's got this stuff figured out.
