Old 04-17-2018, 10:03 AM   #1021
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Originally Posted by ben2go View Post
Make sure the P traps are facing side to side and not front to back. The water can slosh out while driving and let in the stink and gasses from the waste tank.
Hadn’t thought of that. Makes sense. Got lucky and got them both right despite being ignorant.
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 04-17-2018, 10:07 AM   #1022
Chassis: Thomas
Engine: CAT 3126
These are just dry fitted. Yes the tee is backwards. This representative a design change and an obvious solution that took me a while to see.
Previously my final drain was ending up 6” off the ground. Bad news.
By rotating the tee I was able to maintain height before tilting down into the spigot/valve at about a 30 degree angle and keep the ground clearance flush with the skirt.
My Build Thread:
Old 04-17-2018, 10:12 AM   #1023
Chassis: Saf-T-Liner MVP EF
Engine: Cat 3126b
Rated Cap: 71
One thing I havent noticed on your build and had not yet considered for mine is a drain vent, is that even something needed for an rv?
Godspyro is offline   Reply With Quote
Old 04-17-2018, 11:04 AM   #1024
Chassis: Thomas
Engine: CAT 3126
Read the last few posts. It’s there. Yes, vented.
My Build Thread:
Old 04-17-2018, 11:39 AM   #1025
SilentReprieve's Avatar
Chassis: HDX
Engine: 3126 7.2
WOW, what an impressive generator slide out.... beautiful job... the tanks stacked... great space saving idea... nice work there too... I only hope my build comes out half as nice... love the paint scheme as well... great looking bus ...
"Fitting a bus for your lifestyle is certainly easier than fitting your lifestyle into your bus" The journey begins... I am expecting a rough road ahead!!
Jim, Marion NY
SilentReprieve is offline   Reply With Quote
Old 04-17-2018, 01:24 PM   #1026
Chassis: Thomas
Engine: CAT 3126
Thanks! I feel like every stage has compromises, but troubleshooting is quite rewarding. Looks like you have a bus a lot like mine!
My Build Thread:
Old 04-17-2018, 01:25 PM   #1027
Chassis: Thomas
Engine: CAT 3126
Actually installed and has had water run through it!
View from below to see the approach angle for the drain hose.
This is the unit that I plan to use for the tank vent. It will allow me to vent underneath the bus without lots of stinky smells coming out.
My Build Thread:
Old 04-17-2018, 10:53 PM   #1028
Chassis: Thomas
Engine: CAT 3126
Installed the basin for the sink!
Plumbed in the drain!
It comes out the dump port!
Very exciting day!
The water tanks filled and the water pump worked!
I’ve got lots of finishing work to do, but once I install the three inch down tube from the toilet my plumbing will be 100% functional!
My Build Thread:
Old 04-18-2018, 09:02 PM   #1029
Bluthebus00's Avatar
Chassis: C1FE 2509
Engine: Cummins ISB 5.9L 24V ~ AT545
Rated Cap: Seats 5. Sleeps 4
Phenomenal work mounting the tanks! I'm getting to that stage on my build and your craftsmanship answered a lot of the questions about my concepts!
Thanks for sharing!
PS> Sorry about your car :-\ Thank goodness for people with good insurance...
Bluthebus00 is offline   Reply With Quote
Old 04-18-2018, 09:10 PM   #1030
Chassis: Thomas
Engine: CAT 3126
Thanks for sharing!
Glad it helped! Everything was much more difficult to execute than I anticipated, but getting it done.
My Build Thread:
Old 04-18-2018, 09:15 PM   #1031
Chassis: Thomas
Engine: CAT 3126
Tube to black tank from closet flange.
New gasket on the toilet from the recycled RV.
Added a cutoff valve because I hear that RV toilets are common leak sources.
Working toilet!
Added supports for the drains and dump tubes.
My Build Thread:
Old 04-18-2018, 11:44 PM   #1032
Chassis: Thomas
Engine: CAT 3126
My mother-in-law is making curtains! They are turning out great!
My Build Thread:
Old 04-19-2018, 10:21 PM   #1033
Chassis: Thomas
Engine: CAT 3126
No progress on the bus today, but my tools and garage are organized. I can move and think again!
The garage is slowly emptying as components are absorbed into the build. I’ve got a lot left to do, but I feel like I’m over the hump and one by one I’m finishing things more often than starting new ones.
My Build Thread:
Old 04-21-2018, 02:52 PM   #1034
Engine: 5.9
Rated Cap: 77 pas
Wow great work. I know for sure that I will be referencing this thread many many times. Thanks for sharing!
hjorg5 is offline   Reply With Quote
Old 04-21-2018, 03:05 PM   #1035
now that you got plumbing in, before you close everything up, take your bus out on a 30 mile ride over town and through the freeways with your tanks in somew state of fill.. this way you can chec k for any leaks that may occur from slamming over bumps and such in a bus...
lookin great!!!
Old 04-22-2018, 10:59 PM   #1036
Chassis: Thomas
Engine: CAT 3126
lookin great!!!
Good idea! Think I may finish propane and do exactly this!
My Build Thread:
Old 04-22-2018, 11:00 PM   #1037
Chassis: Thomas
Engine: CAT 3126
Thanks! Hope it helps!
My Build Thread:
Old 04-22-2018, 11:14 PM   #1038
Chassis: Thomas
Engine: CAT 3126
So this is what I ended up with. Very messy.
I had to add a second spur to allow the second tank to fill faster. I was just letting it flow through the pex that t’s I to the pump intake and it was taking forever.
I also added a diverted valve so I use water from one tank at a time rather than both at once.
All of this made me afraid that my fittings would get hit and I would break a fitting or worse, a bung.
So I made platforms that go over the hoses so we can store junk without killing the plumbing. They just lift out, but do a lot to easy my mind.
Drain valve for purging tanks.
By the time I finished this the vent lines started looking vulnerable.
And yes I used great stuff to attach the vent line to my existing spray foam. Ugly, but will be hidden and secures well without puncturing the seal of my spray foam.
I replumbed the vents using pex and finding less vulnerable paths.
Then I built boxes over the bungs to keep them safe.
While in the area, I labeled all my electrical plugs.
Gonna have to come back with clear tape to get the labels to stick.
All in all this was a learning experience. I hope it works out, but I feel like the whole tank/pump situation is not elegant.
It all works though and no leaks...
Getting started on propane now.
Looks like I’m going to be able to reuse almost the entire system that came out of the RV with little modification.
My Build Thread:
Old 04-22-2018, 11:40 PM   #1039
[QUOTE=david.dgeorge07;265400]
Attachment 21114
Killer solution—adds insulation, protection, and tacks it into place! Saving that idea for later!
danno is offline   Reply With Quote
Old 04-23-2018, 10:41 PM   #1040
Chassis: Thomas
Engine: CAT 3126
Partial/dry fit of basic propane manifold.
1/2” flare connection from regulator hose to npt 1/2” schedule 40 pipe to 1/2” tee, then 1/2” npt to 3/8” flare.
The three 3/8” flare fittings will feed 3 flare fitted flexible copper lines that will feed the stove, furnace, and water heater.
The stove accepts 1/2” male npt, so I have to adapt back from flare at the appliance end.
My Build Thread:
