09-18-2017, 10:19 PM
#121
Chassis: Thomas
Engine: CAT 3126
I've taken a break from endless removal of stickers, reflective tape and decals to play on the computer a little more. Any opinions on these three mockups?
09-19-2017, 03:41 AM
#122
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
I like #3.
It's hard. I am putting finishing touches on my paint job. It looks good on small screen, but bus is big canvas....
What I did is try before I buy- I tinted the primer to better visualize.
Here are some ideas to confuse you further.
09-19-2017, 07:50 AM
#123
Engine: 8.3 Cummins, 643
I also vote #3 I think it's mostly where you have the lines on the bus I like better but the colors look nice also.
09-19-2017, 10:28 AM
#124
Chassis: Thomas
Engine: CAT 3126
Originally Posted by Rusty
I like #3.
Wow! Those are a lot of ideas for sure! My goal is to create something that isn't too boring, but that isn't nearly impossible to pull off.
09-20-2017, 07:05 AM
#125
Chassis: Thomas
Engine: CAT 3126
Finally got all the reflective tape off. Any tips on removing the adhesive residue?
09-20-2017, 07:19 AM
#126
try 3m adhesive remover, goof off, or a rubber wheel if all else fails.
09-20-2017, 11:46 PM
#127
Chassis: Thomas
Engine: CAT 3126
Another pre-vis
09-20-2017, 11:49 PM
#128
Chassis: Thomas
Engine: CAT 3126
I've tried acetone, goof off, and a rubber wheel. I suppose it will get done eventually, but good grief. I thought the hard part was getting the tape off, I think this is going to be an even bigger chore!
09-21-2017, 06:48 AM
#129
It took me a few days to get all the adhesive off my shorty.
09-22-2017, 09:38 PM
#130
Chassis: Thomas
Engine: CAT 3126
Not done but the end is in sight. I tried the rubber wheel again and it did help a lot.
09-22-2017, 11:09 PM
#131
IF you wear it out, they're a LOT cheaper online than at local retailers. I got em for ten apiece vs the $35 I paid for one at the auto parts store.
Glad to hear its working out!
09-24-2017, 06:45 PM
#132
Chassis: Thomas
Engine: CAT 3126
Finally started painting!
09-27-2017, 06:15 PM
#133
Coachwork: Crown / Pusher
I'm thinking next big rainstorm what I'll do is rent a industrial blaster & strip mine in the driveway
09-27-2017, 06:35 PM
#134
Traveling
Rated Cap: '00
Looking good- did you degloss that paint, because yours was shiny. They have liquid deglosser, but i prefer sandpaper- #220 light.
Paint top-down for less spatters. block-it on for first coat, then come back w/ tape for detail lines.
09-28-2017, 06:18 PM
#135
Chassis: Thomas
Engine: CAT 3126
I sanded it.
10-03-2017, 03:07 PM
#136
Chassis: Thomas
Engine: CAT 3126
Well it's two months and counting on the inquiry with Thomas to write a letter to unlock sixth gear on my transmission. Just got a response yesterday from them that another similar request has been denied recently. I did not realize that they did not relatively routinely authorize this kind of thing and now I'm nervous that they're going to deny my request.
10-03-2017, 03:35 PM
#137
Traveling
Rated Cap: '00
You may have better luck shopping Allison techs. Make sure the shop does the bigger 3000 series stuff. It will tell you on Allison's dealer locator what they service. Ask to speak to the tech, try not to use the word 'bus'- RV. My local shop said he'd do mine for $300, but he wants whole vehicle, so I am finishing my paint so it looks nothing like a school bus.
Good Luck
10-03-2017, 04:22 PM
#138
Chassis: Thomas
Engine: CAT 3126
Good Luck
Well, I talked with the local Allison shop and it this is what they said they need. Hopefully it will be ok since others on this side with near identical busses have been approved. If plan A doesn't work then I'll start thinking more seriously about plan B. Allison shop quoted $150 for the work.
10-03-2017, 04:54 PM
#139
Traveling
Rated Cap: '00
Sounds like he is by the book. Great price, but requires letter form coachbuilder signed by engineer, usually. There was another post where they got it done for $275 IRC without the impossible letter..
10-04-2017, 02:41 PM
#140
If I recall, CadillacKid took out his transmission control module entirely and shipped it off to an aftermarket transmission builder with a note explaining that he was building <something not a school bus> and needed it. You might want to check with him, or read his transmission swap thread.
