Old 10-15-2020, 09:41 AM   #81
witchywoman's Avatar
Year: 2006
Rated Cap: 30
Started on the plywood subfloor. I have leavened that I suck at precise measurements. Ha! Oh well. Luckily no one will see the edges.
8F1EAA9B-8AF3-423D-A195-78871B432E77.jpg   AB9B4980-7A29-4249-AE04-79BA62814FD8.jpg
witchywoman is offline   Reply With Quote
Old 10-15-2020, 01:17 PM   #82
Engine: C7 Cat
Nothing to complain about there, you are making fantastic progress.
Keep up the great work.
Cheers.
Oscar1 is offline   Reply With Quote
Old 10-15-2020, 02:25 PM   #83
It looks like you're already doing this, but just in case: you want to leave a small gap between the edge of the plywood and the bus wall (or the step wall), maybe 1/8" or so. This will allow the plywood to expand in hot/humid weather without causing any warping problems.
Old 10-15-2020, 04:48 PM   #84
Year: 2006
Rated Cap: 30
Well I did it by accident due to my cruddy measurement skills but it’s there! Ha!
Old 10-16-2020, 01:54 AM   #85
Uh, those are planned expansion gaps!
Old 11-08-2020, 07:23 PM   #86
Year: 2006
Rated Cap: 30
Last emergency hatch is out! Started working on a reading nook over the rear engine. Once it’s done it should be nice, dark and goth like.
48EDFC57-3BAA-42F1-A171-378E7C259E8C.jpg   CE51FA3D-8014-4A58-8F67-C074013FC2DA.jpg
Old 11-09-2020, 02:24 PM   #87
Dark for a reading nook?
Old 11-09-2020, 02:36 PM   #88
Year: 2006
Rated Cap: 30
We are going to have some cool gothic lanterns and twinkle lights. I have a cool vibe planned that will suit my offbeat style.
Old 11-22-2020, 11:47 AM   #89
Year: 2006
Rated Cap: 30
Wheel wells done!
Finally got the wheels boxed in. And we had a furry visitor!
1C716ACD-1CEE-4972-8991-06E3ED77ED1F.jpg   52C4CB05-E7C2-4DF3-ABBD-B2566F325B0D.jpg
Old 11-28-2020, 12:16 AM   #90
Does your carpenter charge extra for a cat-scan?
Old 11-28-2020, 03:28 AM   #91
cntryby's Avatar
Chassis: AARE
Engine: 8.3L / MD3060R
Rated Cap: 46
Nice bus, that HC door will give you a lot of options.
cntryby is offline   Reply With Quote
Old 11-28-2020, 07:31 AM   #92
Year: 2006
Rated Cap: 30
Right now I’m planning to use that handicap door for an outdoor shower. We’ll see though. Yesterday I started laying down my floor plan and then started changing my mind a million times.
Old 11-28-2020, 10:23 AM   #93
That door would make a really great place for a slide out kitchen nook. You may want to keep that cat. I hear they make great shower mats if you just flatten them out a bit.
Old 11-28-2020, 12:48 PM   #94
Year: 2006
Rated Cap: 30
Poor kitty!!!
I actually don’t have the best construction skills so can’t do a slide out kitchen but that is a good idea.
Old 11-29-2020, 12:10 AM   #95
In my book, that's exactly what the blue tape is designed to flush out!
Old 12-02-2020, 04:51 PM   #96
Year: 2006
Rated Cap: 30
The thin layer of insulation over the metal ceiling is done!! Next step, plywood before a fun finish. Though I need to buy a roof vent before I close everything off.
83C14509-2A8C-4AF6-BBE9-67D17656EBD3.jpg   C5294692-0C58-403D-AF58-9E018D35C7EF.jpg
Old 12-07-2020, 04:01 AM   #97
Very nice bus, and those seats are nice. Any unique plans around the side door where the wheel chair lift is? Good luck with it all. Looks like you're just under a year since your purchase!
Timber Moments is offline   Reply With Quote
Old 12-07-2020, 05:56 AM   #98
Year: 2006
Rated Cap: 30
I’ve always planned to use that space as an outdoor shower. I’m not going to be living in my bus. It will be used for camping on weekends and as a mobile yarn/crochet store.
When I first started looking for buses I saw pictures of someone using that space to plan a shower and I thought it was a great way to save on interior space.
Old 02-05-2021, 08:49 AM   #99
Year: 2006
Rated Cap: 30
Framing doors and a prob with hoses
More complicated than I thought to frame out the emergency doors but I came up with something that works for me!
Though here is my question. Did any if you have AC hoses running up the wall that you kept? If so, how did you cover them? I thought about building out a box like contraption that will stick out from the wall. But if there is a better idea I’m all for it.
AC2FBA5F-5C37-4F0B-AEF0-7EF485318DE9.jpg   F5AFD406-C714-4400-8F2F-49E0523C3525.jpg   CF3B1AB5-6D80-4819-9AB1-DB733F5653A4.jpg
Old 02-05-2021, 02:24 PM   #100
Chassis: TC/2000
Engine: 5.9 Cummins 12-valve
Rated Cap: 1
Three or four inch pvc pipe cut in half? Could also use the couplings to make the bends if needed. Then it could be painted to match the theme of your build.
BamaBus is offline   Reply With Quote
