Old 02-05-2021, 02:28 PM   #101
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
look at line set covers.
Old 02-05-2021, 03:53 PM   #102
witchywoman's Avatar
Year: 2006
Rated Cap: 30
I’ll have to check into pipes or line covers. Neither was on my radar.
witchywoman is offline   Reply With Quote
Old 02-05-2021, 04:43 PM   #103
Engine: C7 Cat
Originally Posted by witchywoman View Post
The thin layer of insulation over the metal ceiling is done!! Next step, plywood before a fun finish. Though I need to buy a roof vent before I close everything off.
Great progress there and your bus is looking fantastic.
You must be getting excited to get to the interior finishing stage.
Keep up the good work.
Cheers
Oscar
Oscar1 is offline   Reply With Quote
Old 02-05-2021, 07:19 PM   #104
Year: 2006
Rated Cap: 30
Oh yeah. I am super impatient now to get to the real walls, paint, floor and more. If only I could quit changing my mind on the floor plan. Haha!
Old 02-05-2021, 07:58 PM   #105
Box it out and turn it into a coat rack?
Old 02-06-2021, 05:11 AM   #106
jonb8's Avatar
Engine: 466
Great job on your bus, don't worry about the floor plan changing... It'll change right up until the time it's done...
jonb8 is offline   Reply With Quote
Old 02-21-2021, 06:39 PM   #107
Year: 2006
Rated Cap: 30
Have to find a truck to use before I get more wood so we painted one of the emergency doors. I’m liking the blue.
Question, did you folks put the final flooring in before or after you finished the walls? I plan on using vinyl flooring if that helps.
Old 02-21-2021, 06:50 PM   #108
I'm not planning on putting in the final flooring until I've lived in the bus for a year. 100% chance I'll trash it otherwise.
Old 02-21-2021, 09:03 PM   #109
Engine: C7 Cat
Vinyl plank and laminate flooring should be installed last, they need to be able to have some ability for expansion so you do not want them trapped or nailed down by your walls or cabinets.
Work is looking good, keep at it.
Cheers
Oscar
Old 02-21-2021, 09:56 PM   #110
If you use vinyl roll goods as flooring use the dense hard kind nor the soft squishy kind. The soft stuff snags and tears easily.
Old 06-24-2021, 08:15 PM   #111
Year: 2006
Rated Cap: 30
Huge progress has been made. The bathroom is built for the most part. We put in an old dresser that will be the kitchen sink, painted that and started working on the bathtub area.
5CDF09BB-0D3A-4CB5-99A9-446B93BFCBDD.jpg   B3ABA957-F7BF-41A2-9536-48C181BA2DD3.jpg   CDA382BB-D675-4E9D-947E-74E272D587D2.jpg
Old 06-24-2021, 08:49 PM   #112
Chassis: TC/2000
Engine: 5.9 Cummins 12-valve
Rated Cap: 1
Good to see you are still at it. Is that the kitchen sink in the back window?
BamaBus is offline   Reply With Quote
Old 06-24-2021, 08:50 PM   #113
Bert06840's Avatar
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Engine: Cummins ISL 280
Rated Cap: 26,000 lbs
I love it!!
Bert06840 is offline   Reply With Quote
Old 06-25-2021, 04:41 AM   #114
Year: 2006
Rated Cap: 30
The kitchen sink is on the left looking towards the back. It’s just in front of a black wall. That back area is going to be the bed with a reading nook over the engine. I’ll try to take some better pics this weekend.
Old 07-11-2021, 09:54 AM   #115
Year: 2006
Rated Cap: 30
After 2 weeks of virtually no bus work we finally got to work finishing the outside of the bathroom. Still a little more to finish on it but it’s turning out pretty good.
Old 09-30-2021, 04:59 AM   #116
Year: 2006
Rated Cap: 30
Many projects nearing completion. Still need to figure out the bathroom door, finish framing the bed, put seats in the dinette and a few more. But it’s nice to see a light at the end of the tunnel.
D36E1F8D-3D1D-4FB0-AE40-A6BC9D8762E3.jpg   6579DAB6-F245-4824-8361-07DD7D1AA9CF.jpg   BB83222F-ACEB-4B5A-88ED-BC7A453084FE.jpg   68568408-6AF5-45EA-930B-A629B09C6004.jpg
Old 09-30-2021, 06:55 AM   #117
sportyrick's Avatar
Chassis: F33695
I used a folding accordion door, magnet holds it closed, Velcro strap holds it open and out of the way. Simple, flexible, cheap and durable, mine has been working for 15 years. Of course you can't lock it closed but why is that important if you are all family. A solid door is a pretty dangerous thing in a moving vehicle, plenty of ways to get hurt if it doesn't stay in place.
Old 10-06-2021, 09:18 PM   #118
Curious about your ceiling materials. Did you leave the factory ceiling, foil faced bubble wrap then paneling? Looks great so far especially with no prior power tool experience.
Murfpcola is offline   Reply With Quote
Old 10-07-2021, 07:55 AM   #119
Year: 2006
Rated Cap: 30
Thanks! It is the thin foil type insulation then Luan plywood. I used the 4 x 8 sheets but cut them in half to bolt them up there. There is a visible seam but it doesn't bug me. The painting still has a way to go but that is being done by my daughter who lives a couple hours away.
Old 10-15-2021, 12:52 PM   #120
Year: TBD
Hi, This is amazing progress! I really like your artistic approach to it all! I can't wait to see the end result... My fiance and I just started looking for our Bus and it seems to be a rare thing to find but it is what you found! ( size, engine, tranny) I am curious as to how you came to find yours? any response would be greatly insightful and helpful thanks!
Kirbee is offline   Reply With Quote
