Old 06-29-2020, 11:26 PM   #341
Engine: Cummins 5.9 24v
Rated Cap: 54 passenger
I've been using 3-1 oil. it seems to work well enough. There's no cap of course, just like everyone else's.
JDSquared is offline   Reply With Quote
Old 06-30-2020, 07:50 AM   #342
Chassis: TC RE
Engine: 8.3 Cummins MD3060
You're doing a lot better than me, man. Bout 30 minutes out in that heat and I'm done.
Originally Posted by JDSquared View Post
LOL I spent an hour out there today. Got three holes drilled into the bus. That was it I was done.
I think I'm pretty much done till September now.
It was 30 degrees on my way in to work this morning. It'll probably top out at 75 today, but beginning next week will be back into the 90's. Goofy weather so far this year, matches up with all the rest of the goofy things going on in 2020!
Originally Posted by TomA View Post
Most people spin most drill bits too fast if they can, and put way too much pressure into dry drilling. Download a speed chart and you'll be surprised how slowly the mfrs recommend drilling. Here's a good one, for really good quality HSS bits listing maximum speeds.
https://www.imperialsupplies.com/pdf/3660-5_F_Drill_Bit_Sheet_Update.pdf
You mean HSS doesn't mean go as fast as the drill will spin?
I have been trying to pound that into my kids heads for years. I finally bought a nice set in 1/64th increments and keep them locked away from the boys. My oldest boy (24 ay the time) got ahold of my Silver & Deming set once and used one to waller out a large slotted hole. He quickly found out why I keep my bits locked away from them!
JackE is offline   Reply With Quote
Old 07-07-2020, 04:15 PM   #343
Rain rain go away so I can get on top of my bus and play.
Old 07-07-2020, 09:27 PM   #344
The pattern where I live for a couple weeks now has been: 1) daily predictions of rain and thunderstorms, 80% to 90% chance, followed by 2) no rain at all. Apparently you've been stealing our rain.
Old 07-08-2020, 02:31 PM   #345
It's been heavy when it comes. And always when I have time to head out there
No rain yet today. Running errands and trying to get there.
Old 07-08-2020, 02:36 PM   #346
My $300 Craigslist find. The tool boxes are perfect. Two of them with the same key. The other open boxes aren't too deep. 6ft x 17 x 10" deep. Under the bus I'm not sure I will like them. They can fit between my solar panels. But not sure what I need to store up there in them. Click image for larger version
ID:	46476Click image for larger version
ID:	46477Click image for larger version
Old 07-08-2020, 03:43 PM   #347
Great boxes, that's a nice find.
Old 07-11-2020, 06:51 PM   #348
Well. That sucks. Has my ladder against it. Dumb.Click image for larger version
Old 07-11-2020, 07:17 PM   #349
Somebody used your ladder to break in? Or you put your ladder against the window?
Old 07-11-2020, 07:30 PM   #350
LOL the second. I don't lock my bus, still haven't fixed the lock I broke on the ride home. They wouldn't need a ladder.
I got so used to the ladder being in one spot, against the open window at the shower. Window stays open no problem if it rains in there. Ladder stays there, never think any more about breaking a window.
But I welded my frame about 1/4" too tight and the solar panel couldn't get in there. So I moved it, was on the ladder grinding and rewelding. Then I was on the roof at least 10 minutes before I heard something and didn't realize what it was until I came down and saw it.
Old 07-11-2020, 07:57 PM   #351
Do you think that's more dumb or less dumb than stepping on a window you laid on the floor while thinking "this is dumb, I'm probably going to end up stepping on this"?
Old 07-11-2020, 10:32 PM   #352
Call it a tie?
Old 07-11-2020, 10:39 PM   #353
Haven't had a picture in a while. I have 4 panels secured in place now. Aside from the broken window I have a tiny bit of forward progress.
Here's a close-up of the z brackets I spent too much on and didn't end up using as they're meant. The bolts that came with them weren't long enough. I used the self tapping screws that came with it. I expect to replace them at some point but will monitor for now before buying longer bolts.
Got up early-ish this morning. Started working on the bus about 9:30. 20 minutes work 20 minutes hiding from the heat. I was over it by noon. Went back about 6pm.
Thinking of getting up at 6am but it's 11 and I'm still drinking coffee so we'll see.Click image for larger version
ID:	46572Click image for larger version
Old 07-11-2020, 10:47 PM   #354
In battery news I've had two panels connected to the battery I think 10 days now. Running two ceiling fans and the bathroom fan 24/7 and getting about 4 hours of float charge every day now.
The BMS isn't working yet. I assume it's because of the shunt not being connected. And I'm still waiting on my inverter to draw amps through the shunt anyway. Kind of ignoring it for now. But the batteries are in the hall. Cut up wires in the floor. The bus is a mess and starting to bother me. But I'm staying on the roof till that's done.
This is the part where I wish I knew what I was doing lol. But I was thinking earlier I should have got the batteries and the panels and the ac before the summer. But I knew even less about this back then anyway. I'm definitely putting a fridge in here the moment I get my inverter. I need access to cold water.Click image for larger version
ID:	46574Click image for larger version
Old 07-14-2020, 05:41 PM   #355
I've got turn signals on the side of the bus.
Right underneath the rack supports.
Guess who drilled through the wires? On both sides!
They feed up the channel between the windows. Oops. Click image for larger version
ID:	46649Click image for larger version
Old 07-14-2020, 08:21 PM   #356
I was going to post Nelson Muntz from The Simpsons, but I decided it would be too mean.
Old 07-14-2020, 09:03 PM   #357
After I tell you the second part, maybe you should.
Because after I realized what I did on that side, I went to the other side, and figured I would drill through the first layer of steel, but not cut the wires, so I could maybe feed them through better before finishing my hole.
And drilled through the wires on that side as well.
And I really believe I'm the smartest one in my family.
Old 07-14-2020, 09:06 PM   #358
That laugh sounds so weird when you listen to it over and over again. It even has a kick drum sound in it.
Old 07-21-2020, 02:56 PM   #359
Larger than I expected. And not the inverter I originally ordered. That never came. After a month I got a hold of the company. They're having trouble hiring enough people. In China. So I guess what I ordered isn't even manufactured yet.
I cancelled and bought a fuelzero unit. I don't know much about the company.
Still working on the rack on the roof. Still. Ten minutes at a time, twenty minute heat break. After driving around all day in the heat with limited ac. But getting closerClick image for larger version
Old 07-21-2020, 04:28 PM   #360
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
I've been working on my bus at midnight. It drops to 80°F. I just hate having to use the headlamp to see. But working under the doghouse, I need to use a drop-lamp anyway, so not really a big deal...
