02-08-2008, 03:37 PM
#21
Re: Bussin' It - the Conversion
Workin fine for me with the newly updated firefox
oh, and nice bus you got there.
02-21-2008, 10:13 PM
#22
That wood stove set-up is way cool! In fact the whole bus is way cool!. Chuck is right, your website is nice and easy to navigate. Very nice job all around. We're just down the road in Abilene. When we finish we'll have to stop by.
04-30-2009, 04:52 PM
#23
lookin good. I just re-read your whole thread earlier this week as part of inspiring myself and also as part of making sure all the ideas are fresh in my head.
Seeing it on video is a lot different from still pics and words. Thanks for taking the time to share it with us.
jim
04-30-2009, 11:40 PM
#24
Engine: 3208 na boat anchor
If enough people watch your vid you are going to be responsible for driving the the price of a skoolie shell up.
You show how a steel tube can be made into a great RV.
The coach converter crowd is obviously jealous. You got a better rig at a fraction of the price!
04-30-2009, 11:55 PM
#25
very nice work and as said before "nice music". Sure is different to see the bus in moving pictures. Have to remember that when ours is finished.
05-03-2009, 08:20 AM
#26
Year: 1994
Rated Cap: 54
Thanks so much Jesper Clan for taking the time to document your project!!!
Your bus was the inspiration that launched our project!
Den,
11-15-2009, 09:37 AM
#27
Chassis: Ford B700
Engine: 5.9L Cummins
Look into the Nason 2k urethane. It has an integrated clear coat (how, I dont know) and has a good shine to it. A bit pricey but by the time you bought a the xo rust and a seperate clear coat I would think itd be about the same. The guy that painted my bus swears by this stuff, says it holds a shine for years and is very durable. I have xo rust on the interior and it is already starting to dull a little.
08-05-2010, 11:12 AM
#28
Chassis: Safe T Liner
Engine: 3208 turbo
Wow great job - I don`t like to just do the at aboys but some projects are just so out standing and this one not just for the work but the web lay out and presentation. Like the Brown Crown and so many others on this website. Its efforts like yours that have Inspired so many others to take the first step to begin thier own project. Some times I wish I had kept more windows.
08-11-2010, 01:21 PM
#29
Rated Cap: 79 at Birth
The carpet projects looks like it is coming along really well...I think it makes for a great looking roof.
08-11-2010, 03:02 PM
#30
Glenn,
Most of what I had to cut around on the carpet were pretty easy, so it wasn't a big deal to do the carpet last. One of my concerns was also that if the carpet goes up first, there may be a small amount of movement between studs and the ceiling panels when you start to build walls because you are going to have the spongey carpet between the stud and the ceiling. The carpet may add a little "give" to the walls/studs when you fasten them to the ceiling.
As for the odors, that has not been a problem for me. I have the traditional vent fan over the oven and and additional fan up on the roof behind the drivers seat. The carpet is not going to absorb any more odor than the couch, chairs, ect will, in my opinion. No one has ever came in the bus and told me what I had for dinner the last night and my carpet has been up now for well over a year. I think it really depends on what you think looks good in your bus and what works best for your conversion.
08-13-2010, 12:38 AM
#31
Engine: DTA360
Rated Cap: 16
I just read your blog... Very cool...
I like the way you worked out the problems you came across...
Great idea on the bunks storage...
Have you had any issues with the grout on the tiles??? Or any issues with the wood stove???
I appreciate the time you took to make your build available for others to use as a guide...
08-19-2010, 11:22 AM
#32
Looks really nice
08-19-2010, 02:04 PM
#33
Engine: DT466/AT545
Ceiling looks great! I will be doing something similar except with cork instead of carpet. What exactly are those wood strips? Are they thin enough to bend without using moisture?
08-19-2010, 05:07 PM
#34
Engine: 3208 turbo
Sweet looking - maybe a little liquid nails for back up - but it looks like some thing the Brown Crown did.
08-20-2010, 12:21 PM
#35
Don't give up, its lookin good. I originally tried the screws as well, but ran into the same problem, it weakens the board and they snap. So, I bought a 4x8 foot piece of panneling and cut the strips 1 1/2 inches thick on my table saw. Then I decided to try and use liquid nails instead of the screws because of the same problem you ran into. The liquid nails worked fine. Use your curtain rods to hold the strips up there for drying. The downside is that with the curvature of the roof, you will need to let them dry overnight at least...so don't get in a hurry.
08-20-2010, 12:52 PM
#36
Engine: DT466/AT545
What about using that thin rectangular trim that is about 1.5"-2" wide and about 1/4" thick? It comes in 8' strips. It might be a bit wider than you would normally use for that application, but maybe it would bend easily without breaking and also be wide enough you could use screws (with holes pre-drilled in the trim of course).
You might also consider some thin brown or black anodized aluminum strips - although that might get pricey.
08-20-2010, 02:02 PM
#37
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
what about screen lath, its what you use to go ever 2x4s on an old screen room. pre drill and you will be good to go. 1 1/2 wide and is 1/4" thick
08-21-2010, 01:11 AM
#38
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
I couldn't cut a straight line either until I picked up one of these, now straight lines are a breeze! Just something to consider...
10-16-2010, 04:37 PM
#39
Looks very nice!!!
10-22-2010, 12:40 PM
#40
Coachwork: Ford
Chassis: Carpenter
Engine: 7.8 New Holland
Hey there jespers!! i love how updateded you keep your conversion i must say it has been wonderful to help me do some planning for my soon to be conversion!! thanks again! Anyways, i love the idea to conserve with the 2 bucket sink system, and how is it holding up? also, you and BC with the carpeted roof is an awsome look and functional idea keep it up please!!!
Mike
