Old 04-17-2021, 09:44 PM   #1
Bustav
So, I figured after a few weeks of working I should probably start a build thread to maybe unwittingly offer up some nugget of information that someone down the line may be able to use.
A little background on the bus- it's is a 77 passenger 2001 Freightliner FS-65 with a Thomas body. The bus is from one of the Denver school districts. I believe it is the higher roof variant (the ceiling was 6'5") The total length is just shy of 40ft and it's got a 5.9 Cummins with an Allison MT 643 transmission.
So far I have just been stripping it down to the outside skin and ribs(so many screws). I've removed all the plywood and rubber flooring and found a few spots where it had rusted a bit too thin for my liking and welded some plates over those spots. I've got a mechanic coming out early next week to double check how the bus is doing mechanically (I drove it from Denver to central Illinois without any issues) and then I will be proceeding with converting the rust on the floor and getting that sealed and the doing a 14" roof raise.
More to follow.....
A Crafty Beaver is offline   Reply With Quote
Old 04-18-2021, 08:34 AM   #2
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
Sounds like you'll be a "Busy Beaver" with your potential plans! Sorry, I couldn't help myself;-0
Good luck and post pics of the project, if you can...
Old 04-18-2021, 05:13 PM   #3
Quick tell if it's a high roof is to look at the side windows in relation to the drivers window, if the sides are higher than the driver, it is high roof. Low roof will be in line with the drivers window.
Old 04-21-2021, 07:19 PM   #4
Cool, then it definitely is a high roof, gonna make it higher.
I've spent the past few days grinding, cleaning, grinding again, and then cleaning a few more times to prep for the rust converter which I just rolled on today.
I've also removed the interlocks for the back door and the emergency exits as well as thinned out some of the unnecessary wires (speakers, interior lights, interlock system etc)
Have a mechanic coming by in the morning to give the bus a professional once over. Fairly confident but I'm not a diesel mechanic.
https://justbetweenbus.com
https://www.instagram.com/justbetweenbus
https://www.youtube.com/channel/UCtgvs2efpziupiH2iEVEciQ
Old 04-25-2021, 09:44 AM   #5
Corroseal went on without a hitch. I think I laid it down a bit thin, I used about 3/4 of a gallon for 250 sqft(coverage should have been 1 gallon for 200 sqft) It still seemed to work well and today, we will be painting the floor with a top coat.
Mechanic took a look at everything and besides tires(which you could see were bad from space), the only thing was the airbags for the rear suspension were showing some signs of dryrot.
Old 04-25-2021, 11:39 AM   #6
I noticed your "so many screws" comment, many have rivits instead. You had it easy. Put your location in your profile, it'll help you out.
Old 04-25-2021, 07:31 PM   #7
Oh I know, I saved most of the decent ones and was toying with the idea of reusing them for the reskin. Pop rivets are not cheap. Think the best I found so far for 3/16" stainless closed end rivets was around $0.13 a piece. I should need about 1500 or so. Which means get 2000...
Any ideas I might be overlooking? I've thought about solid rivets (and have the tools to work with them) but don't know if I want to deal with them...
Old 04-25-2021, 11:42 PM   #8
My International was mostly screws, but some rivets. Where ever a rivet got taken out, it was replaced #10 panhead square drive screw.
Old 04-26-2021, 07:37 AM   #9
More to follow.....
Looks like you got a pretty sweet bus to begin with. Good on ya!
Old 04-26-2021, 10:41 AM   #10
Rivetboy's Avatar
My Ingersoll rand compressor "Garage mate" and 2 new IR air hammer guns and my buddy helping, we removed all of the ceiling and all of the sides in 2 days. This was a 28 foot bus. You certainly need more infrastructure to remove rivets and a good source of air but with the right equipment it went pretty fast. Also. my bet would be on a few of those screws stripping out and needing to be chiseled off any way... Finally, a pancake compreesor is not a good source of air to run 1 air hammer and trying to run 2 air hammers would be futile.
Rivetboy is offline   Reply With Quote
Old 05-02-2021, 02:03 PM   #11
So, been steadily chugging along, I've gotten the steel for the roof raise and the rivets should be arriving sometime in the next few days, pulled out all the windows and am working my way through the row of rivets above the windows. I found that if you cover the rivets with duct tape and then drive them out, the duct tape keeps them from flying off all over the driveway/yard. I have also welded in the brackets for the threaded rod for the roof raise to keep everything stable. Still have about 30% of the rivets on the top row to go, still glad that the entire interior was not done with them lol.
Old 05-15-2021, 12:17 PM   #12
Just dropped a video on youtube about the rust conversion and floor painting
I've also successfully raised the roof and started reskinning the bus in the last week or so, had a few days of calm wind and no rain and couldn't pass it up. Things went as smoothly as I could have hoped for and I haven't run into a issue worse than stubborn rivets. Having the bus roof sitting up on 4 bolts and nothing else was..... interesting, definitely glad I waited for a day with next to no wind. Once I got about 4 of the new columns welded into the hat channel everything firmed up considerably. Now I just need a few more days of clear weather to continue working on the skin and I can enjoy the oven that the bus will become....
Old 05-25-2021, 07:26 PM   #13
Just wrapped up getting the sides of the bus reskinned. I still have the back to do along with covering a few holes in to roof where the emergency exits were and where some other stuff was sticking through. And the front transition, which I had been going back and forth between doing in fiberglass and steel. Seems the general consensus is steel but wouldn't mind hearing more opinions.
Also new video on YouTube is out on the window removal and roof raise prep.
https://youtu.be/ApYG6LAzoKk
Old 07-08-2021, 06:55 AM   #14
Roof raise finished
So, I just wrapped up the roof raise and reskinning of the major bits over the long holiday weekend. I've been working a new job which is sucking most of the coolest hours of the day away and haven't had a ton of time to work on the project. However, I did finally get to a point where I dont have to keep a tarp over the bus to keep the rain out. I'm sure there are still a few leaks here and there and I still have to remove and reskin over where the emergency hatches and fan/vent are, but I'm claiming victory. The transition from the original roofline to the new roofline gave me a bit of trouble, mostly just trying to plan it all out in my head before using expensive material on it. Sometimes you just have to go at it and make up a plan on the go.
Old 07-08-2021, 08:29 AM   #15
That roof raise look great !
Old 07-08-2021, 08:45 AM   #16
Roof raise looks great, and it's nice to see even sketchier dognose scaffolding than what I used!
Old 07-08-2021, 09:19 AM   #17
The little platform is actually pretty stable.... the ladder to get up onto the hood not so much.
Old 07-08-2021, 09:20 AM   #18
Thank you. My wife told me that it looked better than she thought it would. High praise!
Old 07-08-2021, 03:45 PM   #19
Chassis: Ford E450
Engine: V10 Gas
A milestone! Great work!
Old 07-22-2021, 09:33 AM   #20
Started some work on the interior framing, I've been using 1x2 to give myself a bit more space for insulation(planning on spray foam) as well as give me something easier to attach the walls to than the metal frame. The 1x2s also faired out the area where the hat channel was cut for the roof raise.
I also got the roof sealed up after I removed the emergency hatches. They were completely toast, the frames were cracked and leaking in several places. I am planning on putting some ventilation in different places and wanted to start with a clean slate.
