Got the rear wall framed up, it might even be square to the floor! I figure if I dont check, I can just assume it is and deal with it later...
I feel like this part of work on the bus is like building a boat, nothing is square.
Eventually I will be cutting the door in half and covering the top half but wanted to retain the ability to transport larger materials.
I've got the front of the bus to do next and that should be even more interesting with the transition(and nothing to attach to in that section)
I also have been prepping for the spray foam insulation to go in, had a local company come out to quote it mostly to see if they could do it cheaper that I could. They came out to be nearly the same price as ordering a few kits of the diy stuff.
