Old 02-23-2011, 07:16 AM   #221
Re: CHANGED AGAIN! THIS WILL BE IT!!
The signs make it look like a suitcase, or an equipment box for a rock band.
I'm not saying that's good or bad. It's not my style (low-key), but it's your bus, not mine. The design wouldn't scare me from parking next to it.
I see you are proposing my favorite "protest" sign for your roof. . . "END ROAD WORK"
Old 02-23-2011, 02:44 PM   #222
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
Hmmmm.. Redbear.. That's a good point. These are the kind of opinions I need to determine my decision. Ha. Ha.
BUSBOZO is offline   Reply With Quote
Old 02-23-2011, 03:23 PM   #223
Seeria's Avatar
Signs... love 'em but you're missing Slippery When Wet
Old 02-23-2011, 04:57 PM   #224
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Ha. Ha. Yeah, that one will have to be for the other side. Keep those opinions coming!
Old 02-23-2011, 07:15 PM   #225
Coachwork: Ward Genesis
Engine: DT466/MT643
Make sure you can prove you are the legal owner of those signs...otherwise, the police might have some really interesting questions as to how you got them!
If you're set on that theme, paint or graphic "signs" might work better.
Jarlaxle
Old 02-23-2011, 09:20 PM   #226
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Sorry.. I did not specify I will be HAND PAINTING EVERY SINGLE ONE! Gonna be a lot of work. But well worth it.
Old 02-24-2011, 05:04 PM   #227
Engine: DTA360
Rated Cap: 16
You have to have a "Dip In The Road" sign...
Looking at it again, I love the idea... Very creative and will defiantly draw people toward it...
dirtygoat is offline   Reply With Quote
Old 02-24-2011, 06:19 PM   #228
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Thanks dirtygoat! Thats a good one also!
NOW TAKING SUGGESTIONS FOR SIGNS!!
Old 02-24-2011, 07:58 PM   #229
yankeflyer's Avatar
Chassis: Safe T Liner
Engine: 3208 turbo
Clearly this a sign of the times.
yankeflyer is offline   Reply With Quote
Old 02-27-2011, 05:12 PM   #230
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
OOOH.. THATS A GOOD ONE.
I started to do the back of bus. I just can't see hand painting all this. THIS IS CRAZY. I really like the theme. But I would also like to be done with it before this summer. Maybe I can try to slimline it a bit. Maybe bigger signs. That would mean less smaller detail?
Old 03-01-2011, 06:20 PM   #231
TygerCub's Avatar
Engine: Detroit
You might want to try finding the signs online at a novelty shop. Many of them are metal, so all you'd have to do is rivet them in place - no painting required. Or, have a sign shop print them using vinyl on magnetic sheets. As long as the sign lies flush to the body, no one will know the difference. And you can change them out as the mood and situation dictate.
Old 03-01-2011, 11:43 PM   #232
MikeyBskunk's Avatar
Coachwork: Ford
Chassis: Carpenter
Engine: 7.8 New Holland
Hey there bozo!! i was just cruzing threw your thread for ideas and plans and i wanted to add to the sign suggestions, you need a SLOW MOVING TRAFFIC TO THE RIGHT painted on the back somewhere i think that would go along great with the theme
Mike
MikeyBskunk is offline   Reply With Quote
Old 03-02-2011, 07:27 PM   #233
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Tygercub.. I though of just riveting signs to the side. But I don't think that will be too clean looking. And there are a lot of rub rail areas. So the magnetic signs wouldn't work either. Thats the only problem with school buses. There isn't much flat sheetmetal.
Mike.. thats a good one! Thanks!
Old 03-04-2011, 08:34 AM   #234
Seeria's Avatar
Can't be too hard to do. Cut a few template sign shapes from cardboard, stencil mats, whatever. Stencils, paint, or spray a base color. Repeat with lettering stencils. Might need to hand draw things like curvy roadways and what not. Love the idea.
Old 03-07-2011, 04:54 PM   #235
Engine: DT466/MT643
And it should be directly underneath the driver''s window with an arrow pointing up!
Jarlaxle
Old 03-07-2011, 04:56 PM   #236
Engine: DT466/MT643
OK, that will work. As for suggestions...
"One way" pointing backwards.
On the back right-hand side: "DO NOT PASS"
On the left rear: "PASS WITH CARE"
Anywhere: "SPEED LIMIT (top speed)"
Jarlaxle
Old 03-07-2011, 07:52 PM   #237
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Thanks for the suggestions guys! While I am at it, I'll return the favor with some more progress pics!!
CABINET DOORS INSTALLED.
I decided to make the interior doors from scratch. I started with 2x4 lumber because it was just barely wide enough for the door handle hole. Then covered them with 1/4" oak plywood on the outside and luan on the inside.
Cutting out slots for the hinges
Drilling for door handle
Stained
Finished with trim
Installed new Jensen Heavy Duty bus or truck radio from Heavydutyradios.com with PA so I can make announcements and annoy my passengers.
Quite pricey though. It is quite rugged and does just about everything.
Installed stairwell handle. $17 from ITC Incorporated (ebay store that sells marine and RV stuff).
Cleaned up the driver's cockpit area. Used the same flooring material as the stairwell.
Some rope lighting
Decided to put the cushions on to see how they looked.
Dinette bench
Working on some trim
I guess somebody does NOT like winter.
This is a bus I drive part time. Its a college campus shuttle bus. This would probably make a good skoolie huh?
Well thats about it for now. Getting close to being done with the interior. Then once the weather starts getting nice, I can start working on the exterior.
Oh.. I may NOT be doing the sign theme after all. I just think painting all those signs would take me FOREVER. SOOOOOOOOOO.... WHAT DO YOU THINK ABOUT THIS IDEA????
Thats it for now!!
Old 03-07-2011, 08:56 PM   #238
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Looking good, love that grab handle and the beadboard paneling.
That paint scheme is much better, I might have to steal it.
It's hard to tell from the picture, is the grab handle the same on both ends?
Old 03-07-2011, 09:21 PM   #239
I like the new paint , I have to be honest I didnt really like all the road signs ideal, but thats just me its your bus. but wow its looking real good, I like your work , keep posting
Old 03-08-2011, 11:09 AM   #240
The door built from scratch looks great. Never thought about that but building a custom sized door is so obvious and simple enough.
Back to the sign theme, you could paint one that reads "CAUTION NERVOUS MOTHER DRIVING" on the rear door as a Partridge Family tribute.
Christopher
skoolz out is offline   Reply With Quote
