Thanks for the suggestions guys! While I am at it, I'll return the favor with some more progress pics!!
CABINET DOORS INSTALLED.
I decided to make the interior doors from scratch. I started with 2x4 lumber because it was just barely wide enough for the door handle hole. Then covered them with 1/4" oak plywood on the outside and luan on the inside.
Cutting out slots for the hinges
Drilling for door handle
Stained
Finished with trim
Installed new Jensen Heavy Duty bus or truck radio from Heavydutyradios.com with PA so I can make announcements and annoy my passengers.
Quite pricey though. It is quite rugged and does just about everything.
Installed stairwell handle. $17 from ITC Incorporated (ebay store that sells marine and RV stuff).
Cleaned up the driver's cockpit area. Used the same flooring material as the stairwell.
Some rope lighting
Decided to put the cushions on to see how they looked.
Dinette bench
Working on some trim
I guess somebody does NOT like winter.
This is a bus I drive part time. Its a college campus shuttle bus. This would probably make a good skoolie huh?
Well thats about it for now. Getting close to being done with the interior. Then once the weather starts getting nice, I can start working on the exterior.
Oh.. I may NOT be doing the sign theme after all. I just think painting all those signs would take me FOREVER. SOOOOOOOOOO.... WHAT DO YOU THINK ABOUT THIS IDEA????
Thats it for now!!
