Old 05-09-2020, 10:15 AM   #61
Originally Posted by dwood443 View Post
Thanks for that reminder. Iíve used fluid film in aerosol cans but never sprayed from a gallon can. I can investigate giving a coat of that this spring. That stuff is sticky and stays a awhile.
I really like that stuff but the smell is unique, not terrible but Iím wondering what a whole fresh sprayed bus will smell like?
Fortunately I kinda like the smell -- at least compared to other products/paints/oils/ and the Fluid Film is relatively non-toxic which I really like.
It will definitely smell for a day or two but I don't think it really lingers -- but I've never done the whole underside of a bus either!
You should wear an organic vapor respirator if aerosolizing that much of it at one time -- nothing you wanna coat the inside of your lungs with...
David
The Murder Bus
Old 05-10-2020, 05:33 PM   #62
Year: 2008
Chassis: 0908S
Rated Cap: 28' 9 window
dwood443 is offline   Reply With Quote
Old 05-13-2020, 02:43 PM   #63
Year: 2008
Chassis: 0908S
Iíve found the air leak in my rear shocks. Can anyone tell me what the part that senses what level shock are is called?IMG_0758.jpg
Old 05-13-2020, 04:10 PM   #64
The following is from the DTNA.com website using the PartsPro to look up the device for our bus:
VALVE-HEIGHT CONTROL, part number: 16-14530-000
(DTNA = Daimler Trucks North America = the Freightliner dealer)
Old 05-13-2020, 06:07 PM   #65
Yeah its what sets your rear ride height. They're a pretty common failiure. Pretty much universal generic parts, from what I understand. Mine's unique but my rear suspension is a proprietary Hendrickson system. Yours is probably Hendrickson but the part looks like a universal one.
Roll Your Own Build Thread
Old 05-13-2020, 06:36 PM   #66
Year: 2008
Chassis: 0908S
Thanks for the name. Once I get my laptop fired up Iíll look up the part number on the build sheet Thomas gave me,
Got the floor down today
Old 05-13-2020, 08:03 PM   #67
Phatman's Avatar
Great feeling ain't it? Good job !!
Phatman is online now   Reply With Quote
Old 05-14-2020, 05:22 AM   #68
Year: 2008
Chassis: 0908S
Its exactly that part number. Thanks again
http://www.thomasbusonline.com/manua.../61310455D.pdf
Old 05-14-2020, 04:11 PM   #69
You are welcome. Thank you for posting the diagram. I stuffed it into my bus folder.
Old 05-14-2020, 06:49 PM   #70
Please tell me how you found the manual for this.
Old 05-14-2020, 07:15 PM   #71
Year: 2008
Chassis: 0908S
I emailed Thomas bus and provided my VIN. I asked for the build sheet. The word doc they provided had html links in it which lead me to the link I provided. If you have a thomas bus and send me a private message I will send you the link to my build for a reference. I don't want to put my link online because I don't want them to maybe remove the content from public access.
Old 05-14-2020, 10:19 PM   #72
Thank you. I will try your technnique. I have a login to the thomasbusonline.com site, but I could not find anything like the diagram you posted. I did find new (to me) interesting things ... as I usually do when I poke around on the site. I have a contact at Freightliner Custom Chassis Company (the folks that *are* Thomas Built Buses) and I will send him an e-mail. If I do not find traction that route, I'll drop you a PM.
Old 05-16-2020, 12:13 PM   #73
Year: 2008
Chassis: 0908S
Come Monday
Got the wall insulation done today. Gonna try to get some wall framing done today too
Old 05-17-2020, 01:18 PM   #74
Year: 2008
Chassis: 0908S
Some wall framing done. Although I think officially ďfurring stripsĒ.
I really wanted to keep the rear windows in view but Iím considering a wall about 16 inches from rear wall for a tool shed, solar stuff, any maybe a water heater.
Does anyone have any pros/cons for such a wall?
Old 05-19-2020, 07:24 PM   #75
Year: 2008
Chassis: 0908S
Come Monday
Got some stuff for inside the bus over the last few days. Some knotty pine cabinet doors I might try to use on walls. I also got some cabinets with granite counters and about 70 square feet of cherry wood flooring.
Just need to complete framing and get these walls up
Old 05-19-2020, 07:55 PM   #76
I love seeing stuff recycled/repurposed into skoolies.
Old 05-20-2020, 01:42 AM   #77
I do like the cabinet doors!
Old 05-23-2020, 05:54 PM   #78
Year: 2008
Chassis: 0908S
Some more progress. Bathroom walls up, basic wiring, Bed frame started. I considered a rear wall and even built it and realized I could not get my cabinets in the front door. Now rethinking and I decided to build the rear bed with access to the door folding somehow IMG_0796.jpg
Old 05-23-2020, 06:39 PM   #79
Can you make the wall removable?
Old 05-23-2020, 06:52 PM   #80
Year: 2008
Chassis: 0908S
Come Monday
Iím going to try something but not sure yet. I want the back for a garage and a place for solar controller and other stuff.
The biggest impact to me is a skinny 2x4í bathroom and having to insulate. With all the patchwork I did in the rear wall I wanted to leave it open/uninsulated in case of any more leaks. I thought Iíd just insulate the new wall.
As Iím writing this maybe Iíll just frame in a removable wall in the hole? This way I can still insulate and slide the wall in and out as needed. (Oh, thatís what you suggested huh?)
Iíve put that part off for now. Just glad Iím using screws because my plans are changing often.IMG_0798.jpg
