Usually you can get a dutch gas mask for about 10 dollars at a surplus place. A gas mask is a bit of an overkill for rust dust. Swatting flies with a hammer. overkill.
I made a wind tunnel between the front and back doors by putting an industrial fan blowing out the back door to suck out all the rust dust. I only had a rust tan on my arms when I was done.
Bob, ever since you put lipstick on your... bus you've been much quieter. You didn't inhale while using that xyline did you?
Robin
Nobody's Business
