Old 12-28-2021, 03:40 PM   #1
Year: 2005
Engine: Cat C7
Coolant Heater Removal and Shut Off
My bus has a coolant heater in the back with large tubes that feed it. I found a block in the engine compartment that has a knob that I believe shuts off the coolant to the inside. My questions are if I close the knob there is a light on the dashboard that lights up saying coolant heater, is it ok to drive with the knob closing it. On the block there is also what looks like a drain, is that to drain the coolant that is in the pipes in the bus? Also, is there a good way to remove the heater without making a mess? Thanks.
Check out my life on YouTube...
https://www.youtube.com/c/HomesteadDad
tororider is offline   Reply With Quote
