Corbie GMC short bus
I purchased a 1999 GMC Savana 350 short bus with wheelchair lift at auction. I started removing seats, by trying bolt removal and grinding off bolt heads. It slow going. My guess is that the rust underneathee has joined the bolts to the frame. I purchased a cold chisel with the intention of hammering off the washers and or punching out the bolts through the bolt holes.
A mechanic somehow disconnected the bus electrics from the base van ones. I'm looking for a fix to reconnect them.
See pictures below
