09-04-2021, 11:00 AM
Year: 2005
Chassis: FS65
Engine: Mercedes 6.4L
Rated Cap: just the 2 of us
Don"s conversion 2.0
Decided to start a build thread.
I found a really nice looking 5 window bus on CraigsList. It was located in Brandywine, Md. I tracked down a guy I knew in Hughesville, Md who runs a school bus service. Offered to pay him a couple hundred bucks to look at that bus for me. He said he would but that he had a bus he had to retire and would sell it to me for $2500. About half the price of the 5 window. I made the trip to Md and bought the bus in October 2019. I hired the seller's son to paint the bus (same guy painted my first bus) also the seller agreed to remove the handicap lift and replace the A/C compressor for the front A/C system. Weather and schedule issues prevented the bus from getting painted until July 2020.
I drove the bus from southern Md to my home in Ohio last August. Bus drove fine but certainly pitched and bucked over a couple of serious bumps on Rt 270. I think new front shocks will help with that. Bus was fine at 65mph but the temp gage would climb when I exceeded 65 and when I was climbing the hills (mountains) of western Md. That will have to be addressed by a mechanic, radiator flush? Fan clutch?
My insurance agent wrote a policy with Progressive which was promptly cancelled by Progressive...but not before I drove the bus home...which was all I wanted anyway.
Since getting the bus home. The interior has been gutted. Metal floor painted with rust converter and rust holes repaired. I had to replace a coolant fitting that had rusted away and I had a A/C tech come out to charge the front A/C system, he had me replace the charge ports then he returned and vacuumed the coolant from the rear A/C and put that coolant into the front A/C system.
The front A/C system now works. I did have an issue with the underbody fans staying on, stuck relay somewhere. I installed a toggle switch for the fans. The rear A/C unit was then removed.
I purchased Matt66 auto sound dead off eBay and installed that in strategic places under the dash and on all vertical portions of the stair well. Working on the stairwell revealed another rust hole which I repaired with galvanized sheet metal. The sound deadening material was then covered with aluminum diamond plate. I kept the original stair treads since replacing them was expensive...almost $200 each.
I have water tanks ordered along with a underbody tool box. I have accumulated a few other items as well. 12V water pump, Heng's power converter, lockable fresh water fill door and a 30amp twist lock power connector.
Pictures are stairwell, I need to use tan caulk around edges of treads. Other picture is just a scrap piece of Formica. I wanted a visual of how low the underbody tool box would hang. Other pics of bus are in my album on this site.
oops...Time stamp on my camera needs to be reset.
09-04-2021, 11:50 AM
Always nice to fall into a better deal. Sounds like you're runniing an AT545 transmission. Your explanation of it's heating issues at highway and mountains is typical for that trans as it has no locking torque converter, so it's always working against the fluid , heating it if put to extreme use. Get a quality trans cooler.
09-04-2021, 12:35 PM
Year: 2005
Chassis: FS65
I thought the AT545 was phased out before 2005.
09-04-2021, 01:13 PM
Thought I read an older model year. sorry.
09-04-2021, 01:55 PM
Year: 2005
Chassis: FS65
I still want to ID my tranny. Tried taking a picture of the plate, exhaust pipe is in the way. I tried the old pencil on white paper to get the numbers..hard to read but I think it may be a 2000. I found some info on the web about Allison 1000/2000 series. Both should have a "Park" position. Mine does not. Next time I get parts from the Thomas Built dealer, I'll ask them to check the vin.
This is the best pic I got of the tranny ID plate. Looks like "2000" in top left.
09-04-2021, 03:11 PM
What does the shifter look like? It'll help identify the tranny.
09-04-2021, 03:42 PM
Year: 2005
Chassis: FS65
shifter has R,N, OD, D, 2 , 1
09-05-2021, 10:21 AM
Coachwork: Crown by Carpenter
Rated Cap: 16
That is definitely *NOT* an AT545!
Woohoo!
09-10-2021, 06:53 AM
Year: 2005
Chassis: FS65
Some progress this week. Floor insulation is down. 3/4 inch foam. I also installed a length of conduit midway between the wheel wells and the the drivers seat so I can run wires across safely. While I had help available, I placed 2 sheets of plywood in the bus. They are not secured to the floor yet.
09-11-2021, 09:36 AM
Year: 2005
Chassis: FS65
plywood floor is installed. Except for area at top of stair well. Carriage bolts will be used to mount the waste water tanks and to secure other heavy items. That will help keep the floor down in the event of a accident. I'll make sure that every sheet of plywood has at least 4 carriage bolts.
09-13-2021, 06:40 PM
Year: 2005
Chassis: FS65
The underbody tool box arrived today. The braces for these tool boxes cost $80...I'll be sending those back as I think 12" "L" brackets from the hardware store will be quite sufficient. I used 1" angle steel across the top of the box and down the sides. The angle covers the gap between the bus body and tool box. Angle is bolted to the box with 1/4 -20 screws, flats and lock nuts. Sheet metal screws across top into the bus body, 1/4 20's down the sides where I could use nuts instead of the sheet metal screws.
I also pulled out the wiring that went to the side mounted "Stop" signs. Still, inside the switch panel is a rats nest of wires. I'm hesitant to remove too many wires as I have no idea what many of them do, best leave well enough alone...the bus still runs after removing the wires today.
09-14-2021, 10:30 AM
Chassis: IH 3800
Progress is looking good and I like the box install. I've been keeping an eye out for a deal on one for mine.
09-14-2021, 02:23 PM
Year: 2005
Chassis: FS65
I ended up using the overpriced braces for the tool box after all. My trip to the hardware store didn't go well. Store employee wasn't very helpful, store didn't have much to choose from in galvanized carriage bolts. I let them keep their "L" brackets as a reward for their not so Steller service.
Tool box came from Northern Tool...with a previous purchase, I enrolled in their "Advantage" program which gets me free shipping. I may buy another underbody box to use for my "house" batteries. Not sure about that just yet.
09-14-2021, 02:24 PM
Year: 2005
Chassis: FS65
Woohoo!
Thomas Built dealer says it's a Allison "2000"...per the VIN.
09-14-2021, 08:14 PM
Year: 2005
Chassis: FS65
Yesterday I read DeMac's post about corrosion caused by a reaction between steel and aluminum. He had aluminum channel on his roof which had supported a A/C unit. Something that my bus also has, and something that I hadn't thought of.
Anyway, I pulled the aluminum channels off my roof and sure enough, there was plenty of rust. Fortunately, the rusty area was only about 10" long. So I scraped off the copious amount of caulking, sanded, cleaned w/paint thinner, scraped more with a razor blade, sanded some more then treated the rust with rust converter. I cut 4 small metal patches from scrap galvanized metal. Hope to finish the roof repair tomorrow...if the weather cooperates.
I did discover that once most of the caulk was removed, I could wipe over it with paint thinner, then the remaining thin film of caulk would come up pretty easily with a razor blade.
Today I also cut a whole in the back of the bus and installed the 30amp twist lock RV electric connector. Not ready to wire the bus yet, but it's one less thing cluttering my desk.
After I cut the hole in the outer bus skin I wanted to drill through the inner "skin so that the holes would line up. However, the drill bit wanted to grab the insulation and twist it. To prevent that, I pulled the insulation apart just enough to poke a short piece of hose through, the hose being just a little shorter than the drill bit. I'm probably not the first person to use this idea, but it sure made life easier.
09-15-2021, 09:53 AM
Year: 2005
Chassis: FS65
I was able to patch the roof this morning. Paint will come another day, I think the rain will start any minute. The rust on one side was pretty bad. Metal seems solid but is very pitted. I was concerned about the unseen rust where the roof panels overlap and also about the rivets, has the rust compromised the seal. So I patched over the entire section. The other side wasn't nearly as bad so I just patched over the holes. Smeared a little extra seam sealer over a couple rivets and along the overlap seam because I was there.
3rd pic, You can see the corrosion on the underside of the aluminum rails.
09-19-2021, 02:22 PM
Year: 2005
Chassis: FS65
This week I received my max-air vent fan and my EcoTemp water heater. Max air recommended a specific sealer which is back ordered.
Deleted the passive air vent today. My patch is approx. 12 x 12. Drilled holes around the patch parameter with drill press, holes about 2" apart. Laid a bead of seam sealer around vent hole and old rivet holes, then around the patch covering the screw holes. Used self drilling sheet metal screws to attch to bus.
09-21-2021, 03:50 PM
Year: 2005
Chassis: FS65
While waiting for my water tanks, I'm doing what I can to move forward. Here is what I did to utilize my H-Cap lift door. I purchased a SS food prep table, 30" x 60". I removed the "cups" from the underside where the legs would attach, attached 1/2" plywood and used "T" hinges to attach the table top to the bus. I suspended the table from the bus with chains which eliminates having to fabricate adjustable, fold out legs. The table will hang level off the bus no matter what the ground has to offer.
Top of the table is about 40 inches...that's with the air out of the bus suspension system.
To finish this, I'll need a couple screw eyes and a bungee cord to keep the table in place when the door is opened, I'll shorten the chain that holds the door open so that the door stays flush with the side of the bus. And paint the exposed wood. I'll give the chains some time to stretch before I start making adjustments, the left chain is a bit too long...1/2 link or so. Maybe I'll insert a spring in the chains to absorb the shock should someone lose their grip when letting the table down.
09-28-2021, 01:44 PM
Year: 2005
Chassis: FS65
3 Steps backwards, 2 steps forward
Gray water tank arrived last week, started to hang it and realized that when I measured for it (fits over the exhaust tail pipe) I had overlooked the 2 exhaust hangers. Doesn't happen very often... but this turned out to be a very easy fix, removed the exhaust pipe from a junction in front of the rear axle. Pipe bends and twist over/around rear axle then two 90's later exits out the rear of the bus with a 6+' tail pipe. Cut the tail pipe leaving one of the 90"s attached then cut the pipe for the length I needed to exit the side of the bus, was able to get the cut pipe to go into the pipe under the bus by more than 3 inches (I had marked 3 inches on the pipe) used the old clamps and put it together. I will need to buy 1 hanger...one of those universal fit all's from AutoZone will work.
The other 2 steps backwards....This past weekend, I was going to install the Maxair vent, decided to ask my wife for her opinion on where to install it. Now she wants me to place large objects in the bus so she can better visualize the bus when completed..large objects to represent seating, kitchen table, cabinets, counter, refer, beds...pretty much everything..
If someone had showed up at that moment, they could have bought a bus on the cheap! So, camping chairs and plastic totes, here we come...
Good news...the other 2 water tanks should be here Friday.
1st pic; the pipe I removed from the bus
2nd pic; used old clamps to reattach "new" tail pipe
3rd pic; exhaust exits the side in front of RR tires.
10-06-2021, 01:27 PM
Year: 2005
Chassis: FS65
This past week, not much progress, installed new marker/clearance lights, 5 red and 7 amber using seam sealer behind them to keep water out of the wire holes, new front shocks and exhaust hanger where tail pipe exits side of bus. Water tanks are here, that's next on the list.
