Old 02-25-2017, 09:17 PM   #321
Went for a ride today after wiggling and tightening everything I could find.
Radio and cruise are working so far. Will get more chances to try it this week.
Old 02-27-2017, 11:52 AM   #322
So- the gremlin is back. Its gotta be a bad ground or something.
I started it up first thing today, and the right wiper was going full blast. The button wasn't moved and I made sure. Nothing would turn it off, so I shut it off and restarted it and everything went back to normal.
So weird!
Old 02-27-2017, 11:55 AM   #323
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
So weird!
Gotta be a ground. It seems to be jumping from system to system, so maybe figure out where those systems overlap?
Old 02-27-2017, 12:00 PM   #324
sure sounds like a ground... I dont THINK that system was multiplexed...
have you or anyone else disconnected any school lights or such yet?
on my carpenter i had a wierd buzzer that would go off and it turnbed out when the school stop sign got yanked that the wire for the solenoid was just flopping around and when it would ground it grounded through another device on the same circuit and would cause a buzzer to go off for no reason... I finally tracked down the wire in the electrical panel and just cut it..
Old 02-27-2017, 04:28 PM   #325
I haven't disconnected anything at all. There was some tv equipment removed, I don't see a strobe light on top, and the four way flashers up top don't light up or do anything as far as I can figure out.
Old 02-27-2017, 08:23 PM   #326
Stewzer55's Avatar
Coachwork: Fisher Body
Chassis: GM "B" Platform
Engine: 350 TBI Chevrolet
Rated Cap: 8
It could have been the TV equipment, depending on the install, it could very well have messed up the grounds.
Closest I have to a Bus would be my '92 Oldsmobile Custom Cruiser Station Wagon 1 of 4,347 built.
Stewzer55 is offline   Reply With Quote
Old 02-27-2017, 08:28 PM   #327
Brewerbob's Avatar
As Caddi implied, it could be damn near anything. Any bare wire that drops the 12volts (likely to blow a fuse but still), a loose ground that is otherwise correct, etc.
Tracing that kind of crap especially on a hack job with no electrical diagram is a nightmare.
