Old 01-06-2012, 07:07 PM   #21
Re: Fear Fair Prison Party Bus
Originally Posted by dirtygoat
Looking good, I really like the mesh... Might have to incorporate that into my bus, would go well with the materials I'm using...
I used upholstery spray years ago that started to bleed onto peoples cloths in the summer when they started to sweat... Just an FYI...
X2 but it was in a trail rig(4x4 truck)that got the seats wet...it was pretty bad...that was back in like1989 tho'
Old 01-13-2012, 11:37 AM   #22
I'm really surprised there is a toilet on that bus. An ex-con I worked with long ago told me about a ride he had on a prison bus. One man per seat, with one ankle chained to the leg of his seat. No talking was allowed, and it was a long and boring ride. At one point they pulled to the shoulder of the road and were told they were taking a restroom break. The guard at the rear of the bus placed a 5 gallon plastic bucket and a roll of toilet paper in the aisle and it was passed towards the front, being used by anyone who needed it. Since the convicts had one ankle chained to the leg of their seat, it was tough to get out in the aisle to use the bucket. When the bucket made it up to the front, the guard up there dumped it out on the shoulder of the road and the bus started rolling again. Hey kids, stay out of trouble.
skoolz out is offline   Reply With Quote
Old 01-23-2012, 09:20 PM   #23
Chassis: Genesis
Engine: Dt40
Apologies for the lack of updates, we've been tied up on some other projects. We did get the lettering finished on the outside, however.
We hope to finish up the stereo installation in the next couple of weeks and take the old girl out for a spin.
bhays is offline   Reply With Quote
Old 01-23-2012, 09:56 PM   #24
PDBreske's Avatar
Rated Cap: 1
That looks awesome, but is it legal? I'm guessing you'll get pulled over by curious cops all the time! Hehee.
Old 01-23-2012, 10:02 PM   #25
Chassis: Genesis
Engine: Dt40
I moved it across town the other day and got some double takes from a few cops, but they all seemed more amused than anything else.. lol
Old 01-25-2012, 08:57 PM   #26
Chassis: Genesis
Engine: Dt40
Seats are installed
Old 01-26-2012, 05:22 AM   #27
overall sharp party bus
Old 02-24-2012, 01:27 PM   #28
Chassis: Genesis
Engine: Dt40
I've been plugging along on a few projects.
The first was a generator for the bus. Since everything onboard except two lcd tv's and a neon sign are 12vdc; it really didn't make sense to me to run an a/c generator and then turn right around and convert back down to 12vdc. So I searched around on the web and found a site http://theepicenter.com/tow02077.html that sells brackets to make your own dc generators. So I am building a 165 amp dc generator. This will let us run all of the stereo and lighting wide open while parked, plus if you ever have a dead battery and can't start the bus, just fire up the generator.
First step was to assemble the motor and alternator and begin building a drawer and frame to hold the generator underneath the bus. This is the same motor Honda lists as being in the EU series generators that are so quiet, but I suspect it will still be a good bit louder than those.
Using some heavy duty drawer slides, the generator will just slide out to be started, fueled, etc. I'm going to mount it right beside the battery box on the undercarriage.
Old 02-24-2012, 01:39 PM   #29
Chassis: Genesis
Engine: Dt40
I've also been working on replacing the bottom step in the entry stairwell, which is pretty eaten up. You can see from the photo, it was in sad shape.
I made a cardboard template and attempted to make a step pan myself from 14 gauge, but that just didn't work out. Luckily a web search led me to Doug at Custom Bus and Truck Panels. http://busandtruckpanels.com/.
These guys are awesome and after I sent the dimensions, they are making me a replacement pan that I can basically drop in. None of the bus parts sites had stairwells for Amtran, so these guys were a great help. I should have the replacement part in the next few days and I can get the step repaired and install the new tread I ordered as well.
Old 02-24-2012, 01:43 PM   #30
Chassis: Genesis
Engine: Dt40
I did learn a lesson the hard way. If you disconnect the air ram that closes the door, then later start the engine... when air pressure builds... boom/crash. I already replaced the glass in the door.
On a happier note, the neon sign that goes on the back wall above the bar came in. It's really cool. The number is our 'Fright Line' that we use in our advertising as a number to call for information about the haunted house.
Old 02-24-2012, 01:59 PM   #31
shoulda said "beer" instead of "fear"
Old 02-24-2012, 02:10 PM   #32
Chassis: Genesis
Engine: Dt40
Good point.
Old 03-19-2012, 11:20 AM   #33
Chassis: Genesis
Engine: Dt40
Getting near the end of this conversion. This past weekend I managed to get the generator and cage installed on the undercarriage.
Installed cup holders for the driver and passengers in front of the cage and also a 12 volt outlet for gps for the driver. I am also finally sorting out the issues with the sound system and lights... taking it out this weekend to a concert I believe.
Also, I finally got the neon sign installed behind the bar. One final little detail to work out on the electrical for that and I should be good to go.
Old 03-19-2012, 01:08 PM   #34
Stuff's Avatar
sweet sign!
Old 03-19-2012, 01:45 PM   #35
can we call collect?
Old 03-19-2012, 03:52 PM   #36
Chassis: Genesis
Engine: Dt40
That's actually our 'fright line' the information number for the haunted house.
Old 05-06-2012, 02:59 PM   #37
Chassis: Genesis
Engine: Dt40
We drove some of our actresses and their dates to the Prom on Friday night... those kids had a blast!
Old 05-06-2012, 03:01 PM   #38
Chassis: Genesis
Engine: Dt40
Old 05-06-2012, 04:28 PM   #39
Stuff's Avatar
ultimate party bus!
Old 05-06-2012, 06:42 PM   #40
That's cool!...better than a hummer limo
our weird little prison windows pictureLOVE Conversion General Discussions 15 09-19-2014 02:44 PM
Prison bus perks Butnerbus Short-Bus Conversion Projects 10 02-07-2013 09:26 PM
2 Prison transport busses for auction -with bars on windows! Abbott Classifieds | Buy, Sell, Swap 10 02-25-2009 02:39 PM
Our New Prison Bus, Blue Bird, International 9.0l letz4wheel Skoolie Conversion Projects 6 01-22-2009 10:26 PM
It's not fair! There should be a law against it!! crazycal Everything Else | General Skoolie Discussions 11 09-17-2008 01:51 PM
