Originally Posted by RamRod4
OMG..... The mechanics at the shop should have asked the gal "are the edges of the hole bent out or in?" and then been able to tell them that "the hole through your "oil container" thingy is probably FATAL, don't pour $50 worth of oil in, just have it towed".
The difference between youth, experience, and judgement....
Youth - You make expensive and sometimes physically painful mistakes.
Experience - After making a number of expensive and painful mistakes, you learn to be much more careful.
Judgement - At some point after the youthful period, you learn to learn from other peoples mistakes and find that it's far less painful and a whole lot cheaper.
I'm going all in with the guy who tried attaching his roof deck supports with double-sided VHB tape - to the sides of his bus, no less. I couldn't convince him of the inadvisability of this, but fortunately the supports came off in his hand before he tried putting the actual deck on them.
WOW......I mean I've used the 3m tape to mount things like window vent fairings but STRUCTURAL? Just WOW. I can see the lawsuit now "you didn't have a warning not to use it the way I did"
I’d be lying if I said I knew what Dunning-Kruger referred to. Had to google that haha.
And now I’m going down that rabbit hole on google.
Thanks John lol
Thanks for the rabbit hole warning....I wiki'd it, read to where the concept was described, and escaped the deep, dark, black hole called rabbit.
