Originally Posted by somewhereinusa
Don't know what you are covering it with. My experience is anywhere there isn't a transfer plate the floor will be much cooler than the places that have it. I think if you add transfer plates everywhere there is a straight run you would benefit. I also put the piping much closer together, three inches I think. I used a much tighter radius on the curves than recommended with no adverse effects. Some pictures here.
https://www.skoolie.net/forums/f11/s...a-6318-11.html
Thank you for the information!
I can add transfer plates, but my radiuss are what they are.
The pex is 1/2 ID. and is pex-al-pex, it was crushing at the 2 1/2 radius I used.
I had the pex already so I used it. Next bus I can use smaller tube.
I really appreciate you sharing your experience! I was using the spacing that an old book I have said.
I was resistant to add spacers because of the cost, but it sure would be silly to have regrets for not spending another $118 on a big scale investment without the ability to change it.
I will go buy another roll today!
I will have plenty tnen, and I can go OCD.
Since I am manufacturing the plates, I can make custom widths to fill where there might be larger gaps.
