01-28-2021, 05:18 AM
Engine: 466
In Limbo Bus
01-28-2021, 05:20 AM
Engine: 466
Well I couldn't get pics to work...LOL I'll work on it.
01-28-2021, 05:31 AM
Engine: 466
01-28-2021, 05:36 AM
Engine: 466
01-28-2021, 06:56 AM
Year: 98
Nice van, 4*4?..
Is that a high roof bus?
Looks that a lot of good work has happened.
Johan
01-28-2021, 08:34 AM
Coachwork: IC Corp
Chassis: RE-300, 42ft
Engine: 466ci
Rated Cap: 90
You two have a very nice van. You're doing a wonderful job on the bus. Slow is paying off by way of a quality build. I look forward to seeing more photos as you build progresses.
DeMac
Frederick Douglass:
"If there is no struggle, there is no progress."
01-28-2021, 11:07 AM
Engine: 466
Originally Posted by joeblack5
Nice van, 4*4?..
Johan
Yes it's 4x4 I built it last year, we just got back from a couple weeks in Key West and Florida overall...
01-28-2021, 11:09 AM
Engine: 466
Thanks Demac if I would just stay on it I would get it done but I keep wandering off into other projects. We have one kid left in college so I've got a little time...
01-28-2021, 05:04 PM
Engine: 345 international V-8
It does look good so far. Neat van too. Hmm need a winch on the bus as well.
01-29-2021, 05:49 AM
Engine: 466
It has crossed my mind,
01-29-2021, 09:27 AM
Looks good! I enjoy seeing the in-progress pictures people post! Also, I am digging the 4x4 van!
01-29-2021, 10:35 AM
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
As others have said, the bus looks good! (x2 on your van)
On your bus, what is the double window front door manufacturer if you know?
01-31-2021, 06:51 AM
Engine: 466
I built the door myself, I couldn't find anything that came close to fitting, that had the window high enough to see out of at a T intersection. If I had it to do again I would have put more time into finding a used class A door and made that fit...
01-31-2021, 07:13 AM
Engine: 466
01-31-2021, 12:27 PM
Chassis: IH3800
Very skilled mechanically it would appear, I'd guess you fabricated the rack on top of the bus also? What is it made of, how'd you anchor it if you don't mind Q&A? Will those 4 LEDs facing out off the racks stay when the bus is done or were those just build site lighting?
Also I really like the bluish green interior paint on the bus, mind sharing the color, it's a really peaceful but not boring color.
01-31-2021, 02:11 PM
Engine: 466
I built the rack out of an assortment of metal, 1 inch angle, 1 inch box tubing and 1x2 box tubing.. I have a stiffener that runs down my bus on both sides and one side rests on it... The lower side of the rack rests on every other rib. Its just for solar so I didn't build it supper strong. Yes the lights will stay, I have 2 on all sides of the bus to light up a boondocking area. The color of the paint is Turquois Cay we bought it at Lowes...Heres a better pic of the stiffener that runs along my roof that I rested the top of the rack on. Hope that helps
01-31-2021, 02:19 PM
Engine: 466
I found a better pic of the rack Maligator.
01-31-2021, 06:47 PM
Chassis: IH3800
Perfect, nice job! Are you going to flat mount your solar or are you going to come up with a way to get some panel elevation for winter months? I'm assuming you bolted the rack on or did you weld the inside courses?
02-01-2021, 06:16 PM
Engine: 466
Yes the rack is bolted and yes I'm just going to mount them flat...I might change that later but for now I got a lot of other stuff to finish...
02-02-2021, 07:41 PM
Engine: 466
Subfloors starting to go down...
