Old 05-15-2024, 04:16 PM   #1
sekkyoshi's Avatar
Making Progress
Making progress Click image for larger version
sekkyoshi is offline   Reply With Quote
Old 05-15-2024, 04:32 PM   #2
sekkyoshi's Avatar
Forward view of cab
Old 05-17-2024, 07:59 AM   #3
nikitis's Avatar
Rated Cap: 29
Looks Cozy af.
Just make sure that wood stove is bolted down VERY well. They are heavy enough to snap small bolts when slamming on brakes. I own that exact one. Also check the bolts where the top of the legs bolt onto the body as they are fairly cheaply made, and aren't really designed to hold against sideways force, but only down force. If you've done that, you should be good. Keep it up.
