Old 11-07-2016, 12:52 PM   #1
MFR Bus 637
I started the conversion. Removed all the seats. I have decided to reuse the folding one at the emergency exit door for a passenger seat in the front of the bus.
Some of the wood is rotted under the rubber flooring. I hope to have all of the wood and rubber removed tonight...
KashMoore31 is offline   Reply With Quote
Old 11-07-2016, 12:52 PM   #2
Does anyone know what transmission my bus has in it or how I could find out?
Old 11-07-2016, 01:37 PM   #3
most likely a 643. Google pics of 545's and 643's and compare. How many gears does it have? What's the shifter look like?
Old 11-07-2016, 05:53 PM   #4
So I called the DMV today and asked what I needed to do in order to register my bus as an RV. They said I had to have the fire Marshall inspect it. So I explained that I didn't have anything to really inspect yet. I was told I had to wait till the entire conversion was done to register it then. So I asked for the fire Marshall's number. I was given the number to Division of building codes for modular homes. Has anyone else had to go through this?
Old 11-07-2016, 07:54 PM   #5
Chassis: IH
What state are you in?
Old 11-07-2016, 09:57 PM   #6
Kentucky
Old 11-07-2016, 11:25 PM   #7
AlleyCat67's Avatar
Year: 2005
Engine: Detroit MBE906
I ran into that with my first project bus so I just titled/registered as a passenger vehicle in order to be able to drive/insure it.
You might also read this thread and give it a try:
http://www.skoolie.net/forums/f18/ho...ion-15292.html
Old 11-08-2016, 07:08 AM   #8
Kentucky
Nice bus country in KY.
Got mine in Elkton.
Old 11-12-2016, 03:24 PM   #9
I finally got all of the wood and rubber flooring removed!
Old 11-29-2016, 09:28 PM   #10
Decals removed
Old flooring and step covers removed.
Old 11-29-2016, 09:33 PM   #11
I had originally planned to paint the existing roof and just insulate and frame over the metal walls. However we had a rain storm come through right after I painted the floor with Rustoleum Rusty Metal Primer. The bus was leaking from several areas. See pics below. I have now decided to go ahead and finish gutting the walls and remove the emergency roof flaps. I am going to find the source of the leaks and repair. Afterwards I plan to find someone to professionally spray foam the ceiling and walls.
