Dory is down at the moment.
We installed a new 24 / 12 battery equalizer and a new starter and tested the engine. All fine, noticed a abs and tranny light coming on. Bus would not move. Shut engine down since it was late and decided to read up on it a little.
Came back a week later. Both batteries dead.
Did and still do not understand why.
Dory has a main shutoff that disconnects both batteries , the 24 and 12 volt circuit. Some fire suppression safety equipment stays on. Not sure about the draw.
As a shortcut I had wired the solar into the fuse panel box so if I would use the main shutoff then the solar would not maintain the battery.
I knew that was a mistake and I should have ran a new wire directly to the battery but ....eh,,,, ehh... I did not.
After the batteries were dead I rewired the solar directly to the battery o have the solar recharge. There is no power where the bus is stored.
Here my second lesson showed up.
The next day the batteries were at 7 volt, 14 volt for two in series.
The charge controllers auto select the battery voltage so they assumed 12 volt.
rewired one battery to solar. Next day other battery to solar . Now both had some charge. Then I put them back in series and reconnected the solar. Success. Charging commenced.
Day three I charged the bus all seemed OK started fine .. but
after 20 seconds the abs lights and tranny light and check engine light came on. I glance by chance on the mppt display ..37 Volt.. 37 VOLT, what the .....
Shut engine of. Voltage back to 25 volts.
Now I assume that the voltage regulator is damaged as in full on.
There are two alternator with different regulators.
prestolite leece neville regulator # 8rl3013b for AC system
prestolite leece neville regulator # 8rl3107 on engine.
Anyone has more info on the difference between these?
The engine one only has the battery terminal wire going to it.
The AC unit seem to have a sense wire.
I did not do further testing but assume one of then died and draws full field current all the time.
I hope my warning lights stay of after the high voltage issue is resolved.
Bought two 8rl3013a on fleabay but have not confirmed that the regulator is the problem.
I have now rewired a 2 strings into 2 x12 volt setups to avoid and compensate for a different discharge of each battery in the 24 volt system.
Later J
