07-03-2020, 01:06 PM
#101
Year: 2005
Back from the dead
Ok, I am back from the dead. We've been a little busy the past two months (having a baby, packing up our house, getting the bus ready to move to the next build location, etc.) but I'm back at it again.
I guess the biggest update is that I made it from Kentucky to Michigan with virtually no issues. I looked a bit ridiculous driving down the road with a bus, motorcycle on the back of the bus, pulling a pickup with a canoe on top and bicycles on the back of that.
I ended up with a pretty janky set up on my tow hitch but it worked for the time being. I'll be replacing it with a more elegant solution while I'm up here. I am going to be building a new hitch that will be bolted to the chassis rather than the bumper so that will help a lot. I will probably keep the supplemental "Ready Brake" system, but I wouldn't buy it again if I had to do it over. If you want to know more about why just let me know.
One disappointment has been the long term stability of my spray foam. It seems like the foam is slowly settling (and in some cases separating from the walls). So I will have to retract my unqualified recommendation of Louisville Spray Foam. I know it is probably at least partially due to my prep of the walls, but the foam looked perfect when I picked it up and I thought it was supposed to set up hard almost instantly. Not sure what happened.
Anyway, next up is running the low voltage lines and sheathing the walls.
07-03-2020, 09:48 PM
#102
That sure sounds like a mistake in application. The company should be held to make it good. However, you have since moved from there.
07-04-2020, 05:49 AM
#103
What kind of prep work did you do on this? I wonder if you got a fine coating of dust on the surface somehow. I'd think that if the foam didn't actually adhere to the surface, road vibration would eventually cause it to do this. I wonder if road vibration could cause this to happen even with well-adhered spray foam, in a situation where you don't immediately cover the spray foam with the new wall material (which would prevent it from sagging and coming out like this).
I wonder if maybe all spray foam jobs in buses tend to separate from the surface like this, but the interior walls and ceilings either prevent it or hide it?
07-04-2020, 06:28 PM
#104
Year: 2005
For prep all I really did was use the wire wheel to try to knock down some of the remnants of the fiber insulation I took out. There was probably dust...ok, definitely dust. I didn't think it was going to be a huge deal since it is supposed to cure rock hard and once that happens it shouldn't move...hypothetically speaking. When I contacted the company he said an oily/greasy film might cause that. He offered to fix it but I had already left town. I just wanted to let you all know to do more prep than I did.
07-22-2020, 10:38 AM
#105
Year: 2005
update
Things are coming along now. I have the walls mostly sheathed.
Seat belts for the long couch installed
Built the short couch that will house our electrical equipment
Built the moveable portion of the couch that will pull out to be a bed
Built raceways for the wiring
And started on the kitchen cabinets
All of which made a looooot of sawdust
07-22-2020, 12:57 PM
#106
Chassis: Ford B
Engine: 5.9 Cummins 12v
Rated Cap: 60
Looking pretty incredible. Great build! Love the propane setup.
07-23-2020, 02:29 AM
#107
Looks like you had snow inside the shop!
07-23-2020, 07:41 AM
#108
Chassis: Collins
Engine: 6.6L LMM Duramax
Looking great!! You are off to a good start! Are you using a Kreg jig for your joints it looks like?
2007 Collins (Chevy Express 3500)
LMM Duramax Diesel with newly rebuilt 4L85E Transmission!
08-06-2020, 09:41 AM
#109
Year: 2005
Just a looooottt of sawdust (or "man glitter" as I like to call it)
08-06-2020, 09:47 AM
#110
Year: 2005
Yes, I am. I built one cabinet with a dado (groove) cut for the floor, but that was a pain since I don't have my actual dado blades here. My education in cabinet building is entirely from Youtube so I've seen people build them both ways. Not sure if there is a difference in long term durability or not.
08-06-2020, 10:22 AM
#111
Chassis: Collins
I like working with steel... So I am also a beginner with wood... So I don't know which way is stronger. I know when I started using glue and a Kreg joint, it turned out much stronger than my previous attempts to build something out of wood!! Keep up the good work!!
09-03-2020, 06:55 AM
#112
Year: 2005
Electricity
09-03-2020, 07:10 AM
#113
Year: 2005
kitchen updates
09-03-2020, 07:23 AM
#114
Year: 2005
mini split install
...Also, our temporary window AC hanging out one of the emergency windows was not cutting it in Kentucky...ick
Thankfully I know an AC technician and he helped me get the mini-split installed!
Here are the brackets I built to support it under the bus. I debated about putting it on the back of the bus versus under the bus and ultimately decided that under was the way to go (I'll just have to do a good job of closing it up and protecting it for the winter).
I was working by myself to get the components installed so I used some ratchet straps to lift the unit off the ground and get it onto the brackets
Then my friend came over and we got started on running the lines
Then we did a nitrogen pressure test and vacuum test. This was the part that I felt like I needed a professional for. It isn't that complicated, but you do need some specific equipment that is quite expensive.
Got the indoor unit installed and fired it up...
Great success! It works! The only problem we had was that the condensation drain was not angled properly and started leaking on us in the middle of the night. Once I re-routed it out the back of the bus I have had no issues with the system at all. I think this 12K Pioneer will be fine for us since we plan to avoid hot weather in general by staying north, but if you are one of those unfortunate souls that lives in the south you will probably need more (or find better shade...or take out more of your original bus windows...)
09-03-2020, 08:32 AM
#115
many of these inside units have 2 drain pipes in the tray.. only one is typically drilled open to the outside.. several peoiple have alleviated the water drip issues by opening that other hole and having two drain lines. as that way even if your bus is parked tilted the water will drain properly..
09-08-2020, 10:08 PM
#116
Year: 2005
Electrical system
Any electrical wizards out there want to trouble shoot my electrical plan???
My 120V AC panel and 50A shore power are already installed and working well. I have purchased four Valence batteries off of Ebay. I think I am pretty well set on the Victron inverter/charger. The stuff that is still a little fuzzy to me is what fuses/breakers are really required. One diagram I saw indicated that there should be a pre-main breaker between the shore power and the inverter but others did not show that. Does anyone else have one? Also, the Victron Multiplus has the capability to charge a secondary battery bank (in this case the bus batteries), what kind of fuse should go between the Multiplus and the bus batteries?
I won't be doing the solar side of things for another month or two so I've got more time to get that ironed out.
09-08-2020, 10:58 PM
#117
Year: 2005
water heater
I am getting close to installing my tankless water heater, but I have run into a bit of a snag with the vent. The vent termination pipe that it comes with is just a straight piece of pipe with some holes around it at the end. The problem is that it will stick out 10 inches from the side of the bus. This is both ugly and likely to get damaged. I have been trying to find some vent caps that are streamlined and don't look ugly but haven't found anything yet. Has anyone else installed an Eccotemp i12? How did you vent it?
09-08-2020, 11:24 PM
#118
Coachwork: 44' Newell Coach
Engine: 8v92T Detroit
Rated Cap: 2 adults and two pigeons
Is there a preference to a water heater made by Suburban (6 gallon) Vs going with a larger unit like above?
--Simon
09-09-2020, 01:14 PM
#119
Chassis: TC RE
Engine: 8.3 Cummins MD3060
The preference is a tankless, or on-demand, heater vs a tanked, 6 or 10 gallon, heater. The advantages of the tankless is you will not run out of hot water. If you are like my teenager, you will want a 110* shower for 45 minutes. The advantage to the tank heater is he will run out of hot water in 4-5 minutes! I'm going back and forth on the water heater only because someone gave me a NOS 6 gallon heater. That's a lot cheaper than buying a tankless heater.
I have used a 6 gallon heater in a RV before. The benefit of it being small capacity is it regenerates quickly. I don't remember having to shower in cold water, but I do remember my showers needed to be as quick as possible. One drawback is you have water sitting in there constantly being kept hot, wasting whatever resource you are using to heat your water.
There are some pretty inexpensive on-demand units on the market, $150 or less.
https://www.amazon.com/dp/B078M9VYRG...v_ov_lig_dp_it
09-09-2020, 02:06 PM
#120
Year: 2005
There are RV specific tankless options as well like this one.
I have heard good things about this brand, however, it only puts out 42K BTU VS the Eccotemp i12 which puts out 80K BTU I believe. Your requirements depend on your environment (how cold your ground water is). If you plan on staying in warm places then it will probably be fine. If you want to take a hot shower after a long day of skiing the backcountry then it probably won't be the best choice.
