Old 09-09-2020, 02:08 PM   #121
DrDanger's Avatar
Year: 2005
many of these inside units have 2 drain pipes in the tray.. only one is typically drilled open to the outside.. several peoiple have alleviated the water drip issues by opening that other hole and having two drain lines. as that way even if your bus is parked tilted the water will drain properly..
Yeah, I saw that. It has been working well so far since I moved the outlet. At this point I don't want to temp fate by messing with it any more
Just some pilgrims, building a skookie
https://www.instagram.com/pilgrim_days/
DrDanger is offline   Reply With Quote
Old 09-15-2020, 07:44 PM   #122
Coachwork: Goshen Coach
Rated Cap: 23
It looks like they sprayed open cell onto metal. They should have used CLOSED cell foam on metal. I had a warehouse metal sprayed. Open-cell spray foam has an R-value of about R-3.7 per inch, while closed-cell spray foam has an R-value that may be as high as R-6.5 per inch.
NOLA is offline   Reply With Quote
Old 09-16-2020, 04:32 AM   #123
DrDanger's Avatar
Year: 2005
It is closed cell. I think the mix wasn't quite right at the beginning (or end) of the job because I only have problems in a few places in the back. The front is totally fine. I've given up caring because most of it is behind wood now!
Old 09-16-2020, 04:54 AM   #124
DrDanger's Avatar
Year: 2005
Built my first drawers ever today. I didn't quite get the side spacing right for the slides, but thankfully I had erred too much in the right direction and was able to fix it with a long shim strip. I am using the Accuride Touch Release slides here so I won't have any drawer handles to trip over/kick. They seem to work pretty well so far, we'll see how they do once they are loaded up and I go around a hard right turn.
Also, I think I have figured out a solution to my water heater venting problem, but this is how I felt the last few days...
Old 09-16-2020, 09:46 PM   #125
I *LOVE* your dino-toon!
Old 09-25-2020, 07:53 AM   #126
DrDanger's Avatar
Year: 2005
Question Battery questions
I purchased some used Valence lithium batteries from ebay a while ago and just got the rest of my electrical components so now I am building a small system to do a bench test.
One thing I discovered is that the bolts that go into the battery are not all the same size and also the positive and negative terminal holes are not the same depth. Say whaaaa???
The result is that the positive bolts tighten down well, but the negative bolts bottom out in the hole before the battery cable is tight and secure. This is ok where I have two cable connections (the ends of each series where they are connected in parallel to the other series), but the middle of each series is loose on the negative terminal. I am thinking of either cutting off the end of those bolts or else add a metal washer.
The question I have is if I get metal washers, what material should they be? Stainless steel? Copper? Other???
Old 09-25-2020, 10:56 AM   #127
Ronnie's Avatar
Engine: 345 international V-8
Copper is the best conductivity. However you could likely get away with plain old zinc plated steel.
Old 09-25-2020, 11:22 AM   #128
HazeltheMooseWagon's Avatar
Coachwork: International AmTran
Engine: International DT466
Rated Cap: 65 passenger - 27,500 GVW
If you use anything except copper you should probably put the washer on top of the lug. Copper washers could go above or under the lug.
HazeltheMooseWagon is offline   Reply With Quote
