Old 04-09-2020, 12:01 AM   #301
tugboater's Avatar
Chassis: Saf T Liner MVP 11 window 32’
Engine: CAT 3126E
Nothing wrong with slow progress[emoji51]. Insulation looks great!
One...slow...step...at a time.
tugboater is offline   Reply With Quote
Old 05-24-2020, 02:36 PM   #302
We have paint!!
Old 05-24-2020, 02:38 PM   #303
Congrats Steve!!!
Old 05-24-2020, 02:39 PM   #304
Almost three gallons of Sher-Kem "Pure White". A quart and a half of hardener and a gallon of xylene for thinning and clean up.
Paint was around $55 a gallon. Hardener $37 a quart and xylene $23 a gallon. I know that I can get xylene cheaper but I was there and they had it in stock.
Old 05-24-2020, 02:41 PM   #305
The paint finish is exceeding my expectations. I was hoping for "50 feet beautiful". It actually still looks ok when you get within 40 feet.
Old 05-24-2020, 02:43 PM   #306
I really want to paint mine but I know how much work it is.
Looks good, man. That weird stuff on the roof end up ok?
Old 05-24-2020, 03:02 PM   #307
Yeah, it is a big job. Nearly killed me on Saturday.
Well, not really, I just wanted to die I got my butt kicked.
I sanded the problem areas on the roof dawn to metal, cleaned, primed and painted. They look fine now except a couple of little spots that are underneath the solar panels.
Old 05-24-2020, 03:04 PM   #308
I have a bashed front cap to deal with. You know that feeling!
Old 05-24-2020, 06:20 PM   #309
Asetechrail's Avatar
Coachwork: Amtran Genesis
Looking real good Steve! I have still done pretty much nothing on my bus.
My railroad here in Montana got shut down by BNSF. April 29th was my last day here. I started working in Arlington Oregon on May 6th.
The commute is a little on the long side at 455 miles! I’m putting around a thousand miles a week on my Honda. Glad it gets good mileage!
Arlington is only 136 miles from your place so I’ll have to look you up one of these weekends once this covid crap settles down (if it ever does).
Asetechrail is offline   Reply With Quote
Old 05-24-2020, 08:45 PM   #310
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
Looking sharp Steve!
Ted
Old 05-25-2020, 11:47 AM   #311
Two spare bedrooms and a comfortable travel trailer in the driveway. Cold beer in the fridge. Come on over!
How does the future look? Any chance of work coming back to Montana? Any plans to relocate to Oregon?
Or...... You could move to Dayton and commute. Between the two of us we could probably have roadable buses by next year.
Take care. Ruthie and you are in our prayers.
Old 05-25-2020, 11:56 AM   #312
Regarding tail lights???
The existing tail lights are pretty utilitarian. I would like to look at replacing them all with:
https://www.raneystruckparts.com/15-...RoCYdYQAvD_BwE
I have red, amber and clear on each side as well as a small light below that is also running/turn. The little one duplicates the function of the big ones. Any reason why I can't delete it?
The linked lights are available as solid on or sequential. I am thinking of stacking three of them on each side. The red and white would be solid on and the Amber sequential.
I think that I would stack them mounted horizontally about 4" apart.
What do you all think?
Old 05-25-2020, 12:02 PM   #313
Dealing with the crashed cap turned out to be more out to be a lot tougher than I expected.
I tried pounding and pulling. Then both of them at the same time. Then I cut it all off....
I am pleased with the outcome. I have a very protected location for my mini splits.
Old 05-25-2020, 12:08 PM   #314
Ted
Thank you.
I keep reminding myself that it isn't a show car. I caught myself trying to fix little flaws in the existing body/paint and realised that I could spend a year at it and no-one but my is likely to notice. Heck with it. I am going to make it white and good.
Old 05-25-2020, 12:24 PM   #315
Rovobay's Avatar
Rated Cap: 35
looking good Steve, What color is the bottom going to be? Painting is a pain. It is the prep work that is the worst. heatgun and plastic razorblade for the decals and stickers, sanding, wiping down with alcohol, masking, it never seems to stop. I still need to paint my rub rails and bumpers with my trim color. also noticed a part on the hood that is a bit light and needs another coat.
My Build: https://www.skoolie.net/forums/f11/sk...doo-22140.html
Follow our build on Instagram at https://www.instagram.com/skoolie_doo/
Rovobay is offline   Reply With Quote
Old 05-25-2020, 03:26 PM   #316
It is going to be all white to begin with. I have not gotten to the bottom yet. I wanted the top painted before I install windows. It is going well enough that , weather permitting, I may continue with the bottom.
When we get on the road we are going to head down to Phoenix to have murals painted on the bus. Take a look at his work: https://www.arizonamurals.net/commercial
Old 05-25-2020, 03:45 PM   #317
Chassis: TC RE
Engine: 8.3 Cummins MD3060
That's the style I am going to use on my bus. I have replaced some trailer lights with these and am very pleased with how they look. I will leave the round white for backup because the holes are already in the lid, but all the rest will be these. I am going to have 4 on each side mounted on a diagonal, 2 as tail blink, 2 as tail stop, with one at the top center and one about halfway down center to act as tail and high mount stop.
This guy does amazing work and he is stinkin fast too!! I was going to have him do a mural on the back wall, but my daughter started painting and is getting pretty good, so I think I'll have her do something instead.
JackE is offline   Reply With Quote
Old 07-04-2020, 06:43 PM   #318
Paint!
A little more progress:
Old 07-04-2020, 08:00 PM   #319
Congrats, Steve! I love it, man!
Old 07-04-2020, 10:15 PM   #320
bus-bro's Avatar
Engine: 3208 na boat anchor
So you loped of a segment of the back roof and you're going to put mini-split compressor units up there. I got to see that in detail. On a RE that last window space is kinda wasted space in the cabin anyway.
