07-09-2022, 02:51 PM
Coachwork: AmTran/International
Chassis: RE 3000
Project Matilda
Well.... we finally pulled the trigger and bought our full-time retirement travel home: working name MATILDA!
I am thinking MATILDA (until/unless the wife overrules me ) due to the song/poem Waltzing Matilda. A Matilda is the bag that carried all the worldly possessions of the "Jolly Swagman" (an itinerant worker in early 1900s Australia). Seems like an appropriate and less overused name like "Wanderer" or "Vagabond".
She is a 2002 International RE3000 chassis with an AmTrans body. T444E engine and Allison MD3060 transmission. 243K miles, rust free, runs/drives well.
1st task is to strip all the "Imma school bus" crap off of it. That and get rid of the seats!
07-09-2022, 03:06 PM
Year: 86
Chassis: Ford B700
Engine: 8.2
take it easy with stripping the school bus crap.
dont need another i cut wires and my bus wont start?
every single safety switch wire cut could be the issue?
good batteries and a charger to start with.
cut a wire/switch and crank the bus.
if it dont connect it back and figure it out before you remove it?
its not cut it all out and why my bus wont start?
07-09-2022, 04:52 PM
Chassis: RE 3000
100% agreed!
If there is one aspect of this build I am completely comfortable with is it electronics/12v electrical.
Looks like the original purchaser school system (that I bought the bus directly from) bus shop was a little..... creative.... with their aftermarket wiring.
07-10-2022, 03:38 PM
Chassis: RE 3000
Strip down Day 1
If anyone from the bus shop of the Richmond VA City Schools district is viewing this....
Your wiring skills need serious work!
Got the stop signs and crossing arm off. 1/2 of the seat bottoms are out and much of the extraneous interior compartments are gone. about 1/2 of the upper wall trim/wire chases are gone as well.
Taking a break! The interior of the bus in the GA summer sun could bake a pizza!
07-11-2022, 10:52 AM
Engine: 3126b 210hp
Rated Cap: 48
Yeah. The Yellow Microwave.
Shade tree is a must!
[emoji3522]Dave
07-11-2022, 06:23 PM
Chassis: TC2000, 40' MPV
Rated Cap: U/K
Your wiring skills need serious work! :
I think people sometimes assume that the maintenance yard for school buses is like a Formula 1 garage, white lab coats, freshly machined and or new parts, clean atmosphere...in reality, it's a bunch of mechanics trying to keep these things running for as long as possible, stealing parts off the ones that quit or are beyond repair. That's part of the reason so many people have problems before they even get the thing home.
"It was maintained by the school district" ...yeah, and?
07-12-2022, 11:17 AM
Chassis: RE 3000
Yeah, I get it....
And the wiring DOES work.... just the workmanship is appalling!
07-15-2022, 07:24 PM
Chassis: RE 3000
Strip down Day 5
Work on Matilda continues. 75% of the external indicators that she was a school bus are gone. Just the front and rear brow "school bus" signs and a few runs of reflector tape are all that remains. Getting rid of all the darned stuck-on-with-adhesive stuff is a flaming PIA.
I am quick-prepping any surface rust patches on the body as I come to them with an abrasive wheel on my angle grinder, some rust corrector, then a coat of primer.
The seat bottoms are gone and most of the upper cushions are as well. My plasma cutter arrives Monday, which is how I plan to deal with the thru-floor seat bolts. All of the school-added features like cameras, child-left-behind systems and door alarms are now disabled/removed.
It's alot of work, but the vision is worth the effort.
07-16-2022, 07:21 PM
Year: 2008
Coachwork: ElDorado National
Chassis: Ford F450 Superduty
Engine: 6.8L V10
LOL. That's what we named our shuttle bus!
07-18-2022, 06:40 AM
Chassis: RE 3000
Did you pick it for the same reason? Kinda unique, ain't it?
07-23-2022, 07:48 AM
Chassis: RE 3000
Strip down day 13
Well, we are slowly making progress. Bus exterior stripping is done less the two big brow "school bus" signs. Instrument panel and console is mostly disassembled. Started this morning cutting the seat bolts with a plasma cutter; talk about the right tool for the job! Makes super quick work of them.
07-23-2022, 12:28 PM
Year: 86
Chassis: Ford B700
Engine: 8.2
i dont have a portable plasma available but i do have a torch and a grinder that i know how to use for 20 plus years now.
hasnt happened to me because its in my mind from seeing actually happen.
plasma,torch,grinder,welding sparks/slag can and will stick to glass and if close enough will embed itself.
word of caution think about the windows and doors when around them.
i sold a man one of my work trucks and he wanted to shorten the legs on the pipe rack and asked for my torch?
i asked if he wanted to pull the rack and he said no i will do it on the truck and i said ok.
i went back to my other projects and 20 minutes later he asked for my welding machine so helped him wheel it out with the fork lift and when we got there the back glass of the truck on both sides were splattered with slag because the DUMB A$$ had cut the legs with the torch pointed directly at the glass?
i am suprised it didnt shatter?
thats how i know it can happen. that was a tinted back glass with a slide but it wasnt my truck anymore.
07-23-2022, 02:18 PM
Chassis: RE 3000
Thanks for the word of caution!
I'll keep it in mind, but almost all of the original glass is going, and I am down low away from the doors/windows.
Basically, we are stripping the bus to primer on the outside, and to the outer skin and ribs on the inside. Complete rewiring and instrumentation. New custom hotel smart control loads for living/camping. Most window openings skinned over and double pane glass where we do keep windows. Custom door to replace the bus air door.
Lots of work for sure but she's gonna be a beaut!
07-23-2022, 08:41 PM
Rated Cap: U/K
Aren't we due for some pictures?
07-24-2022, 08:27 AM
Chassis: RE 3000
Yes we are. But so far they are just as she arrived, and a few of the strip down so far. Really nothing exciting yet.
07-24-2022, 01:58 PM
Chassis: International/IC Bus
The demo days are the days I don’t miss haha. We have the same spec bus from Fairfax County schools. Interested to see what you have planned for your conversion.
07-25-2022, 09:24 AM
Chassis: RE 3000
Stripdown Day 15
Continuing to work on the stripdown of Matilda. Hung up on the damned VCR box a couple of rows back from the driver's seat. Big self-drilling screws hold it down to the floor, but I don't see any way to get at them. Was trying to save the box itself, but it is looking like I'm doing to have to plasma cut it out. Any ideas?
The electrical system for the camper loads will all be "smart" and run via Home Assistant. I have already made "smart switches" with relays and ESP32 microcontrollers for this purpose. We will be able to control our bus from an app!
07-25-2022, 10:13 AM
Chassis: RE 3000
Camera VCR not a problem
OK, So I got the camera box out. Turns out there are two 7-pin tubular locks on the cabinet. The top secures the VCR cabinet, and the bottom secured the VCR cabinet to the rails that are bolted to the floor. Options: 1) Call a locksmith, 2) buy a 7-pin pick from banggood.com and pick it, 3) cut the box open and remove all the vcr guts to get at the bolts.
Then there is option 4. It requires 2 crowbars or heavy pry bars. put one bar under the VCR box and pry up, bending the vcr box up over the bottom lock. Simultaneously, us the second bar to pry the vcr box away from the bus wall. This frees the box from the rails, allowing you access to the bolts below.
Problem solved!
The primary purpose for the floor trim on the drivers side is to run the heater hoses from the engine to the heater in the back and then to the dash. Since I'm deleting the heaters.....
07-25-2022, 12:00 PM
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
W4cbl
Do you have the cameras that were part of the recording device? Can you turn this into a woop de do dash cam?
William
07-25-2022, 01:47 PM
Chassis: RE 3000
William
Yes, I have 1 of them..... but trying to reverse engineer its feed and tie it into my new "smart home" integration would be problematic. And dash/backup cams are cheap.
