11-10-2017, 11:19 AM
#81
Originally Posted by AZtom
We got trafficmaster rustic maple honeytone
Sent from my Pixel using Tapatalk
Thanks
11-10-2017, 01:02 PM
#82
Maybe it's just me but I think you should do a popcorn ceiling.
11-10-2017, 02:40 PM
#83
Chassis: 2003 International CE; 2 A/C Units; PS; Air Brakes
Engine: T444E 7.3L Diesel Engine
Rated Cap: 72 Passengers
what would you suggest instead?
Redheadraptor
11-10-2017, 02:42 PM
#84
Sorry - hit the wrong quick reply - What would use instead? was in reference to 2kool4school's suggestion not to use liquid nails.
Redheadraptor
11-22-2017, 08:00 PM
#85
Chassis: TC 2000
11-22-2017, 09:06 PM
#86
Chassis: Ford B600
Rated Cap: 20 person
Love the bunk beds, its a great idea if you have kids. I also love how you insulated the windows. i might steal that idea.
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
#87
I put the pieces back up using silicone, so far OK.
Don, Mary and Spooky the cat.
11-26-2017, 09:48 PM
#88
Chassis: TC 2000
Progress continues. Framed in the toilet area and the shower room. Did the same style as the bunks area for the windows, insulated and brought the plywood up to half the window
11-27-2017, 01:35 AM
#89
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Looking good !
I bet you are pleased ! It looks very nice.
Will their be other beds below the ones pictured, or is that storage?
You all should make some good memories in this rig.
11-27-2017, 07:19 AM
#90
Chassis: TC 2000
Beds up top and below, 4 kids
11-27-2017, 08:24 AM
#91
Have to ask...
Can those covered lower windows still be accessed to replace glass if needed?
11-27-2017, 09:00 AM
#92
my main concern with using black background would be the temperature... hot sun on those windows is creating a literal green-house between the window and the black background you chose..
12-04-2017, 06:45 PM
#93
Chassis: TC 2000
Originally Posted by Tango
Have to ask...
Well the frame can't be removed so it would make it difficult. I'm pretty confident we could figure something out.
Worse case I could cut the wood out to replace if needed. Or sheet metal the outside like others have done.
Either way no throwing rocks around the bus!
12-04-2017, 06:51 PM
#94
Chassis: TC 2000
There is no gap to trap air to create the green house. The insulation is tightly pressed against the glass. The foam should provide the absorb the heat reducing the transfer to the inside of the bus. Or at least that's the theory. We've had some days in the 90's and I haven't noticed any issues.
We get more heat coming in from the exposed windows. It heats up fast where the light is let in. Need to get on those curtains.
12-04-2017, 08:14 PM
#95
I'll second that. Sun shining through the windows can make the inside temp at least 20 degrees higher than outside in the sun on a hot day. I use the same insulating panels that work so well in the winter to block the heat in the summer on the sunny side of the bus.
Robin
Nobody's Business
12-04-2017, 08:51 PM
#96
Chassis: Saf-T-Liner MVP ER
And the rest.
Sun shining through a car window can raise the outside temp of around 85F to over 120F inside the vehicle.
The Taurus sometimes gets so hot inside that the temp gauge, that tops out at 130F, goes into error.
12-04-2017, 09:40 PM
#97
Last year prior to insulation I was getting those higher temps with my top hatch and several windows open. This was my first summer with the new foam insulation and it stayed quite comfortable, but only with the use of window panels on the sunny side of the bus.
Robin
Nobody's Business
12-21-2017, 08:49 AM
#98
Chassis: TC 2000
12-29-2017, 08:22 AM
#99
Chassis: TC 2000
Benches made, stove installed. Time to move on to wiring and plumbing
01-11-2018, 06:53 AM
#100
Chassis: TC 2000
