Old 05-12-2022, 03:07 PM   #1
Year: 2009
Coachwork: GMC
Chassis: 3500
Engine: 6.6 Duramax
Removing sheet metal screws from side panels
Hello All,
We're getting to do a minor wrap on our mini and I would like to remove the screws on the sides where the wrap will be partially laid. My question is this: Can I remove and re-use the the same screws without any damage to the ribs that the metal is attached to? If I need new ones, should they be a size larger?
I won't be touching the longitudal braces
Thank you in advance.
Don
Hiyu is offline   Reply With Quote
