Just thought we would share some of the low cost home improvments we have done for those budget builders out there.
A really nice countertop for about $40.00 and a few drops of blood.
The countertop is just a piece of 3/4 sanded pine plywood coated with pour on epoxy, for a real nice wet look finish. The underside is framed with 2x4 trimmed down to 2x2. I know, Why not just buy 2x2? Because spf 2x4 tends to be straighter and have less knots, and I have a table saw.
Had a little mishap while setting the sink.
Dropped and caught the sink. Catching was a bad idea.
I knew it when I felt the sharp under edge of the sink contact bone.
Yanked the most of the windows and insulated the holes with 2" Poly foam.
We use a deep freeze and a super insulated cooler to store food. The deep freeze uses about 180W when the compressor is running. The cooler is kept cold by 1 gallon ice packs made with zip lock bags, water and diaper fill. We change the bags daily but can actualy go 3 days and still be below 45 degrees in the cooler.
So to keep it tidy a drawer for the cooler:
To keep it cold longer we built a box for the cooler out of 2" Pink Panther Foam board.
This is how we know it is past time to change the ice packs:
Not wanting to lose any interior space we insulated the outside walls instead of the inside:
We are in the process of dropping the ceiling panels, insulating with 2" Pink Foam and replacing the metal panels. We like the schoolbus ceiling. We love magnets.
Easy light fixtures: Magnet mounted LED Shop Lights.
