01-12-2020, 03:54 PM
#321
Chassis: Collins
Engine: 6.6L LMM Duramax
Keep up your momentum!!! It's looking great! Temporary plywood or not,you're moving forward! We had ice and temps in the low teens this weekend so I didn't get much done on mine...
Originally Posted by kidharris
Food for thought...was it easier because you didn't take the time/effort to square and clamp it to keep it square?
Do you know of any paint primer that is made for welding over? Red iron oxide type primer?
I agree it is harder to build ahead and then fit it in place. But I'm anal so I have to make it square... lol
Yep they make weld through primer. I haven't used any on my bus, but have used some on cars in the past...
01-12-2020, 04:31 PM
#322
Oven shelf done
01-12-2020, 04:48 PM
#323
Well, I did take the same time and effort to keep it square, just failed at it since what I'm squaring off of is a bit wonky to begin with. I think this one was mainly easier since I didn't go through the multi-day process of de-rusting, priming and painting.
@banman recommended that before. I haven't seen any locally and haven't ordered any online yet.
01-12-2020, 05:27 PM
#324
Engine: Cummins 5.9 24v
Rated Cap: 54 passenger
You're getting so much done. It's awesome. Shel Silverstein has a song about having nothing left to roll. What's going to happen when you have nothing left to weld?
And a question about welding to rust. I thought it wouldn't hold? I'm on my underside trying to avoid cutting anything out (except those few spots you saw) and wondering about welding storage boxes, and tank supports etc. And how clean I need to be. Might end up trying to bolt things to the c channels.
01-12-2020, 05:43 PM
#325
I'm going to dance and sing, no concerns there. I'm honestly getting kind of sick of cutting and welding right now, but I have to keep going and take advantage of this fantastic weather.
I'm welding into floor metal in the pic that I made that comment on, it just has a nice layer of surface rust on it - so it's more like I'm welding through rust than welding into it, really. You have to hold the arc on the rusty side a little longer to make sure the weld pool sucks from the solid metal underneath it.
It holds well enough for sheet-metal-on-sheet-metal connecting, but I wouldn't trust it for holding up anything heavy on the underside. My tub tray is entirely welded into the new steel of my frame, and for my gray tank I'm probably going to do something like a heavy T where the top of the T rests on the floor inside spanning two cross-beams and the vertical part projects through the floor to the underside and be attached to the tank (like one T for each corner of the tank). My underside is just too rusty to have anything heavy welded directly to it.
01-12-2020, 06:31 PM
#326
I'm so spoiled here lol. No time no money though in this 74F winter.
My C channels look good. I go back and forth on how bad my rust is. I was a bit depressed yesterday after post Ospho grinding. But I went back a minute today and it looks good. A lot of bare metal on the channels and some rust around what I assume are weep holes.
Every fourth or fifth is an angle iron though, instead of a channel. Those are in bad shape for some reason. And the two I did so far turned black, mostly, like it should. But it's chunky. I'm not sure yet if I can weld to it.
We'll see. Lol I should be posting this to my own thread instead of here.
01-12-2020, 11:50 PM
#327
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
Product names or types of paint?
01-13-2020, 06:05 AM
#328
Heres a self etching weld-through primer-
https://www.amazon.com/Seymour-20-16...37586035&psc=1
Most of the "cold galvanized" cans can be welded through, too.
01-13-2020, 08:10 AM
#329
Chassis: Collins
Sorry I should have put a link in before... I've used Eastwood stuff in the past along with their Rust encapsulator for converting rust. On the bus I'm using POR15 because it was available on Amazon. Here is a link to the weld through primer from Eastwood.
https://www.eastwood.com/ew-self-etching-weld-thru-primer-16-1-oz-aero.html?SRCCODE=PLA00010&gclid=EAIaIQobChMI0Leo9 t-A5wIVSb7ACh1MrQNFEAQYASABEgIyEfD_BwE
01-13-2020, 12:19 PM
#330
Pics from my original bus listing
01-13-2020, 04:15 PM
#331
Welding fail
01-13-2020, 07:07 PM
#332
Chassis: Collins
Well was worth a try. Did the tile break when it heated up?
Have you tried grinding the edge of the joint on the bus side to remove everything down to bare metal?
You have a nice sized gap that should weld good without any backing. (Judging by the picture)
01-13-2020, 07:22 PM
#333
The instant I hit the trigger on the welder, the tile broke with a really loud bang and made me think I had somehow broken something on the frame. It kept breaking more as I kept going - definitely not the correct material for this.
I could normally weld over a gap this size, but the bus metal is too pitted (on top and bottom) for the weld pool to grab it and it just burns it off instead. I should really be replacing much larger areas of the floor, but I just don't have the heart for it right now. I'm able to weld small patches successfully in this area if the patch is on top of the hole (with about 3/16" of overlap), but I was trying this technique with the tile so the patch could be flush with the floor.
01-13-2020, 07:31 PM
#334
Chassis: Collins
I see. Makes sense. I'm glad you tried so other people know it won't work well.
Looking in the picture the top left I agree it looks like the metal was super Rusty. If it disappears the instant you strike an arc, it is probably mostly rust and the patch should be larger. Are you trying to initiate the arc on the thicker new piece of metal, then wash over on to the bus side after the puddle has started?
The weld on the bottom right of the patch looks great! Looks fairly flat like it burned in well and welded to good metal!!
I feel helpless trying to help you over a message board. I've always taught people by showing them in person... Lol
01-13-2020, 07:37 PM
#335
Well thanks for your concern, but you don't have to feel helpless on my behalf. These little holes are just for fun now that I've got the big one closed up.
01-13-2020, 08:33 PM
#336
Rated Cap: me + 1
looks good enough, but if you blow up the pic of the rear, I can see something, but bot alarming
01-13-2020, 08:40 PM
#337
You wouldn't think the entire corner would need to be rebuilt just from that pic.
01-14-2020, 12:58 PM
#338
Rated Cap: me + 1
correct, I wouldn't think that
01-14-2020, 02:13 PM
#339
You need to go farther back in this build thread and see what he did to the back corner. This is the same bus, and what the dealer showed him before he bought it.
01-14-2020, 02:18 PM
#340
