Old 03-28-2020, 09:46 PM   #581
Half-chaise?
Found this on CL:
I've been thinking of getting something like this and cutting off the armrest on the right side and having that up against the side, then an ottoman on rollers at the end to make the whole thing long enough for a bed.
musigenesis is online now   Reply With Quote
Old 03-29-2020, 12:47 AM   #582
Attachment 42602
Attachment 42603
Attachment 42604
This is how I'm going to handle my roof curvature. I'm going to build jigs once I figure out the right depths and numbers of cuts so I can mass-produce all the sections for my ceiling. They should just squeeze in and then be held in place by my front-to-back furring strips. I'm planning to use 1.5" board which will bend a bit more easily on its own than this 2" stuff.
Yeah, but the 2" has 1/2" more uncut (uncurf'd) which makes it easier to bend with said curfs. I totally believe you can do it with the 1.5" foam. It may take a little more planning/practice.
Old 03-29-2020, 12:49 AM   #583
Found this on CL:
Attachment 42605
It could indeed work with or without the arm removal, I believe.
We got a sleeper seat off CraigsList for free and will adapt it as a spare bed in our build.
Old 03-30-2020, 12:53 PM   #584
Fuel tank cover installed permanently
Dry fitting, just to make sure.
Dynatron-550, of course.
Tried to then put the panel on upside-down, with the posts for the smaller hatch sticking downward. Freaked out for a bit because it didn't fit the holes, then realized and flipped it over.
One of my windows is still leaking. It's nice to see the water puddling instead of seeping through my floor. I know where the leak is, fortunately.
View from the underside.
Old 03-30-2020, 02:40 PM   #585
Frochevy's Avatar
Chassis: Collins
Engine: 6.6L LMM Duramax
Attachment 42602
Attachment 42603
Attachment 42604
That is a pretty cool idea! I didn't have that much headroom to use that thick of insulation!! I used furring strips and then polyiso insulation and mine was thin enough it flexed without breaking.
Frochevy is offline   Reply With Quote
Old 03-30-2020, 04:14 PM   #586
The 1.5" XPS is going to go into the cavities between my ribs (on an IC the ribs are exactly an inch and a half deep; on Blue Birds it seems they're closer to 2") so no loss of headroom there. Then I'll use 1X furring strips with 0.75" XPS in between them, so with my 1/4" plywood ceiling I'll only be losing 1" of headroom total off the ceiling.
Old 03-30-2020, 04:17 PM   #587
Frochevy's Avatar
Chassis: Collins
That's even better!!! I left my original insulation in place, then furring strip creating an air gap then polyiso before my T&G carsiding. I think yours will be better insulated than mine.
Old 03-30-2020, 04:45 PM   #588
Strap/hanger thing for exhaust pipe
Made a strap/hanger whatchamacallit out of some scrap galvanized to support my piece of flex pipe in the middle. Couldn't finish attaching it because I only brought ONE FREAKING BOLT to my bus.
Old 03-30-2020, 04:53 PM   #589
We have thunderstorms rolling through right now and the power keeps flickering. In just the few years that I've been living in the Philly suburbs, I've been without electricity for close to a month total, which is vastly more than the entire rest of my life combined. So even in the good times the power going out was something to be very concerned with; these days it's even more of a concern. I'm glad I have two generators, although neither is something I can run all the time.
At my last house (also here in the suburbs) I had a neighbor with a big generator system that came on automatically, so in addition to not having power for long stretches myself, I had to deal with the 24 hour noise of his generator and his floodlights (which came on with the genny for some reason).
Old 03-30-2020, 04:57 PM   #590
Old 03-30-2020, 06:22 PM   #591
Seems like you could bring the bus 'home' now and not have the neighbors be such dicks about it...
David
The Murder Bus
Old 03-30-2020, 06:28 PM   #592
I suspect they'd be even more likely to be dicks about it, since they'd have to be looking at it more often.
Old 03-30-2020, 09:39 PM   #593
You got me ... what is it?
Old 03-30-2020, 09:41 PM   #594
Are you going to paint the inside floor surface yellow to match?
Old 03-30-2020, 10:23 PM   #595
Oops, uploaded the wrong pic.
Old 03-30-2020, 10:28 PM   #596
Yeah, that's the plan. The inside doesn't really have to be yellow since it will all be covered by the subfloor, but it eases the logistical strain to only have one color of Rustoleum to stock up on.
I was going to make the wheel wells black but now I'm thinking yellow, and these will be visible from the outside, of course. I'm kinda worried that staring at this much yellow for so long has warped my aesthetics.
Old 03-31-2020, 02:56 AM   #597
It will make for an interesting picture, to be sure.
Old 03-31-2020, 07:13 AM   #598
Found this on CL:
Attachment 42605
I have an OLD one of those from my grandparents. Its tiffany blue.
Its pretty comfy, I'd imagine it could double as a bed.
Wear A Mask- Stop the Spread!
Old 03-31-2020, 07:34 AM   #599
I found an even better one:
This one's ideal because it's very narrow (29") and has a perfectly rectangular footprint. Its main flaw is that it's in Jersey so I probably won't be able to get it until July, if then.
I have this tendency to fall in love with CL/FBM stuff and then be disappointed for a long time when I don't end up with it.
Old 03-31-2020, 07:50 AM   #600
I'll bet stuff like furniture will be real cheap in a few months man. Could probably score a new one cheap if you're vigilant.
build thread
