08-29-2019, 06:28 AM
#81
Looks like classified gov't top secret bus pics.
08-29-2019, 04:47 PM
#82
More bondo and my new mail slot
08-29-2019, 11:14 PM
#83
It's a combination of not wanting to show my license plate number and not wanting to see my own bald head.
08-31-2019, 07:02 PM
#84
Starting on repairing other corner
I cut this piece and it fit perfectly first time. Never happened before.
And then I welded it in place in my usual haphazard style. That has happened before.
Welded hole patch experiment.
More frankenwelding to stitch on the new outside panel. I somehow keep convincing myself that I will be able to weld over 1/8" gaps when in fact I can't.
09-04-2019, 07:28 AM
#85
looking good, keep cracking on
09-11-2019, 07:29 PM
#86
Mondo bondo
09-12-2019, 08:51 PM
#87
09-13-2019, 04:16 PM
#88
Welded floor patches
09-20-2019, 05:23 PM
#89
Rear light panel reinforcement: fun with rivnuts
1/8" galvanized plate cut to fit behind lights ($8.25 for a 48" x 8" piece, love me some Fazzio's):
Locked into position with four 1/4-20 screws. These may not have been necessary but they held it in place initially and will at least take some stress off the rivnuts.
Closed-end rivnuts in place of the original sheet metal screw holes. My initial attempt at placing one of these a few days ago resulted in the rivnut nosepiece breaking. This time I clamped the two pieces (original bus body and new plate) tightly with small c-clamps through the center hole, and then I had enough chooch to crimp the rivnuts properly without snapping the nosepiece. Rivnuts went in "wet" with seam sealer.
This might be overkill for the lights, but these openings were a major source of leakage (both from the big holes and the screw holes) and I want to make sure these stay dry.
09-23-2019, 07:22 AM
#90
It's about what gives you piece of mind, or at least that's what I tell myself when I over engineer the crap out of something.
If nothing else, you're refining you rivet smashing processes...
My load standards officer use to say "don't practice until you can do it.... practice until you can't f@ck it up"
looks good
09-24-2019, 06:20 PM
#91
Right side light reinforcement
09-24-2019, 08:09 PM
#92
Great effort!
Way to eat the elephant, one bite at a time!
I like a product called "duroglass". It's like bondo BUT it's structural having long glass fibers and a more epoxy like base.
For welding across a sheet-metal gap -- If you have access to both sides -- hold a piece of copper tube or plate under the gap. It will keep the weld puddle from falling through and the weld won't stick to the copper.
I'm on the road so no access to my saved links but getting a better helmet with a bigger screen will quickly make you a better welder. I don't mean a $200 Lincoln helmet either -- good stuff for under a $100 but HF ain't it.
09-24-2019, 08:18 PM
#93
Originally Posted by banman
Great effort!
If I can get a helper, I may try having them hold a copper plate under the small holes when I weld them over so I don't have to create a giant metal turd to do it. Thanks for the tip on that. That's something that would have been very useful when I was welding the bent piece of angle iron for my corner repair.
I hear you on the helmet.
09-26-2019, 04:19 PM
#94
09-28-2019, 07:41 PM
#95
Nice work.
09-29-2019, 10:18 AM
#96
Priming and new tailights
09-29-2019, 02:02 PM
#97
The licence plate light should be wired to come on/off with the parking/running lights.
No need for a separate circuit, and for sure NOT always left on.
Just splice it to the tail light wire.
09-29-2019, 03:56 PM
#98
The license plate light bulb is the running light bulb, there's just a clear lens under it. Where are they leaking from? The wire hole? Have you used a proper grommet for sealing hole and wire?
10-02-2019, 02:36 AM
#99
Hey Musigenisis ... rust remediation is a tough job. Your bus and ours both suffer from the wheel well rot and the back light drip. I sympathize with you. However, it does feel GREAT to get rid of a hunk of RUST and make it solid again. Keep up the good work.
10-02-2019, 05:59 AM
#100
Thanks, man, appreciate the kind words. It is indeed tough but I feel all this work is giving me more of an emotional attachment to this hunk of steel ... which is probably going to lead to more bad decisions down the road.
