06-04-2020, 08:20 AM
#981
Engine: Cummins 5.9 24v
Rated Cap: 54 passenger
Thanks. I sure wish I had a completed skoolie right now, would be most handy.
Well mine of my family will crap in a bucket lol. They love everything about the bus except that. So even if it was ready I guess I'm evacuating alone.
06-04-2020, 08:31 PM
#982
This bit spans multiple crossmembers on the underside, and I'm putting 3/8" bolts down now for eventually attaching my gray tank.
I needed a way to fix these bolts so I can run nuts on from the underside, but I can't (or more accurately, won't ever again) weld the heads because they're Grade 5.
This resulted in the nastiest thing I've ever welded. The bit of bar I welded on to prevent turning and then the bit of nail on top prevents it from being pushed up, but I didn't snug it against the bolt enough and it could still turn, so I welded on another bit of nail to fix it. Just ugh, but I'm going to leave it because it's functional and I need to punish myself.
Had a big storm yesterday which knocked out my power (wont be back up until Sunday night, it seems). Right when the power went a bunch of sirens started up, and my street was filled with fire trucks:
House near me caught fire and one of the two brothers that lived there died on the second floor:
https://6abc.com/delaware-county-sto...re-in/6229618/
06-04-2020, 08:35 PM
#983
Ha, same with my family. My brother and his wife were excited about borrowing my skoolie to go camping, until I explained how a composting toilet works. "Oh. Ooh. No."
06-04-2020, 08:58 PM
#984
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
Attachment 45324
Attachment 45325
weld 2 pieces of bar stock/strap or 1 piece with notch to prevent turning and epoxy (JB Weld) to hold the bolt down. How do you know where you want the bolts?
06-04-2020, 09:26 PM
#985
I'm going to use two bars on each bolt as you suggest. My gray tank is going up against the fuel tank cage on one side, so I know exactly where the supports on the other side (by the chair rail) are going to go. I would definitely prefer to install the tank first and then lay down the subfloor, but it is what it is.
06-04-2020, 10:23 PM
#986
I don't have any problem with "tack" welding a grade 5 bolt to the substrate. Just don't over do it. You can, as an alternative, run a bead of weld on the substrate along two faces of your bolt to keep it from spinning and even weld a "cap" over the bolt top to keep the bolt from lifting while you are assembling the nut.
I suppose another way to keep bolts in place would to be using a bolt with shoulder serrations (like a lug stud)--nah, tack the sucker.
06-05-2020, 02:59 PM
#987
Cab disassembly
06-05-2020, 03:58 PM
#988
In preparation for .... painting ?
06-05-2020, 06:36 PM
#989
Yeah. I wouldn't have decided that I don't want the bulkhead wall any more. If it hadn't worked out, I think I would have quit the entire project instead.
I am a little worried about how difficult it's going to be to reassemble. The weld boogering to bend the frames back square put a lot of strain on the connections between the frames and the bus wall/ceiling. It might take a lot of coercion. I was considering just leaving it in place but decided to proceed with my original plan.
06-05-2020, 06:38 PM
#990
I think I may just tack them and forget about it. I massively munged the bolt heads for my chassis clips, but they torqued down to the specced amount without snapping.
06-05-2020, 07:56 PM
#991
If you put a solid tack on two sides of the bolt head it will neither turn or lift.
I still think you should experiment with welding the entire head of a grade 5 or 8 bolt to some plate scrap. put the plate in a vice and see how much torque it takes to break the bolt -- see if the bolt doesn't shear before the head/welds break. Most important, then decide if the welded bolt is still taking as much torque as you need? Especially where you're requiring tension over shear strength.
I've made my own nutplates, welding a grade 8 nut to a piece of flat stock. I wrecked the cadmium plating but I don't think I lost enough (if any) strength to matter...
06-06-2020, 05:05 AM
#992
Rated Cap: me + 1
I would think that what the bolt is holding and how many bolts are doing the job would play into whether I welded, tacked, or not. Not all bolts are holding the body onto the frame.
Not getting the bolt too hot would also factor in. Over sizing the bolts is also an option if losing strength is the problem. Small holes drilled thru the heads are also an option. Stick a wire/rod thru the hole and weld it.
Is the problem not having someone else to hold the bolthead? Millions of bolts are installed every day without welding them in. Not all bolt heads have to be hidden, unless you are an Italian car designer.
Maybe you are a little obsessed with this.
06-07-2020, 10:49 PM
#993
06-08-2020, 10:33 AM
#994
Lemme guess ... water tank rails?
06-08-2020, 12:39 PM
#995
No, underbody brackets for the rails for my transit van seat and the pieces for my hack reinforcement of the back end. I was just taking pics of the notches I cut in the pieces to ID them. I have this habit of writing where a piece goes with a sharpie and then painting over that.
06-08-2020, 01:52 PM
#996
First screw
Said the heck with it and welded the heads. As usual, taking it down to bare metal made welding it a lot easier.
Focus, you
First go at welding a screw instead of a bolt.
Dowel goes down easier on a wood screw than on a bolt. Whodathunkit?
Couldn't find my bolt cutters, so I rigged a way of cutting the screws easily (if not necessarily safely).
06-08-2020, 03:30 PM
#997
Safety covers
06-08-2020, 08:20 PM
#998
06-08-2020, 09:48 PM
#999
Rustoleum on wood?
I've always wondered what would happen if you painted wood with Rustoleum. I'm gonna find out since I just accidentally painted one of my plywood floor pieces with Rusto clean metal primer instead of Valspar wood primer/sealer. I was wondering why the paint suddenly felt so different.
06-08-2020, 11:46 PM
#1000
Year: 86
Chassis: Ford B700
Engine: 8.2
i used to work with an older man that drove screws in like 8d nails and when you asked him about it he would say that the slots in the head is for taking them out not puttin them in?
i can understand that with a slotted/flat head screw cause i hate them.
